Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Change Material of part in assembly - Inventor 2014 / 2015
5 REPLIES 5
GeorgK
782 Views, 5 Replies
Hello together,
how could I change the material of a part in an assembly? I would like to select the part and change the material.
This works in part-environment:
http://adndevblog.typepad.com/manufacturing/2013/07/inventor-2014-api-set-part-material.html
Thanks Georg
5 REPLIES 5
philippe.leefsma
in reply to: GeorgK
Hi Georg,
Here is a sample that sets an occurrence appearrance:
Public Sub SetOccurrenceAppearance()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    ' Get an appearance from the document.  To assign an appearance is must
    ' exist in the document.  This looks for a local appearance and if that
    ' fails it copies the appearance from a library to the document.
    Dim localAsset As Asset
    On Error Resume Next
    Set localAsset = asmDoc.Assets.item("Bamboo")
    If Err Then
        On Error GoTo 0
        ' Failed to get the appearance in the document, so import it.
        ' Get an asset library by name.  Either the displayed name (which
        ' can changed based on the current language) or the internal name
        ' (which is always the same) can be used.
        Dim assetLib As AssetLibrary
        Set assetLib = ThisApplication.AssetLibraries.item("Autodesk Appearance Library")
        'Set assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")
        ' Get an asset in the library.  Again, either the displayed name or the internal
        ' name can be used.
        Dim libAsset As Asset
        Set libAsset = assetLib.AppearanceAssets.item("Bamboo")
        'Set libAsset = assetLib.AppearanceAssets.Item("ACADGen-082")
        ' Copy the asset locally.
        Set localAsset = libAsset.CopyTo(asmDoc)
    On Error GoTo 0
    ' Have an occurrence selected.
    Dim occ As ComponentOccurrence
    Set occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select an occurrence.")
    ' Assign the asset to the occurrence.
    occ.appearance = localAsset
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
GeorgK
in reply to: philippe.leefsma
Hello Philippe,
thanks for the answer. I tried to change it for material. Could you help me to get it running?
Georg
Public Sub SetOccurrenceMaterial()
    Dim Name As String
    Name = "1.0120 St37k"
    Set localAsset = asmDoc.Assets.Item(Name)
    If Err Then
        On Error GoTo 0
        ' Get the Autodesk Material Library.
        Set assetLib = ThisApplication.AssetLibraries.Item("AD121259-C03E-4A1D-92D8-59A22B4807AD")
        Set libAsset = assetLib.MaterialAssets.Item(Name)
    On Error GoTo 0
    'How to change?
  Call asmDoc.BrowserPanes.ActivePane.TopNode.DoSelect
End Sub
philippe.leefsma
in reply to: GeorgK
Hi Georg,
You need to set the asset to the occurrence.appearance property
The CommandManager.Pick method should return the selected occurrence or null if the user cancelled the selection.
Hope that helps,
Philippe.
Philippe Leefsma
GeorgK
Hello Philippe,
thanks.
Cheers Georg
gkniksch
This works great for changing the appearance, but how can I excute a similar macro that removes the appearance override?
Thanks!
