Change Design View in IDW
9 REPLIES 9
Message 1 of 10
698 Views, 9 Replies
Change Design View in IDW.
Followupfrom a thread from Years ago..
Lookin got get designViewrep name in Drawing FIle.
Sub DesignViewRep()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDrawingView As DrawingView
    Set oDrawingView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select a drawing view")
    MsgBox oDrawingView.ActiveDesignViewRepresentation
End Sub
Above macro from Daniel is not working.. please fing avi file attached.
hope we will get some soloution for a simple and small issue.
9 REPLIES 9
Message 2 of 10
djreesing
What Inventor version are you using? I tested the code with Inventor 2013. See below for a section from the programming help. I looks like it's in the API since Inventor 11.
What is the problem with the code? do you get a runtime error or just an empty msgbox?
DrawingView.ActiveDesignViewRepresentation Property
Parent Object: DrawingView
Description
Property that returns the name of the active Design View Representation for a drawing view of an assembly. This property returns a null string for drawing views of parts & presentations and in the case where the model (assembly) is unresolved.
Syntax
DrawingView.ActiveDesignViewRepresentation() As String
Version
Introduced in Inventor version 11
Message 3 of 10
in reply to: djreesing
Hii..
It is just retuning an empty MsgBox. If you have any File Transfer (large file) I can send you debug video.
Just an Empty Msgbox. Nothing else.No errors.
Message 4 of 10
djreesing
Are you selecting an assembly view?
This line in the help will explain the empty message box: "This property returns a null string for drawing views of parts & presentations and in the case where the model (assembly) is unresolved."
Message 5 of 10
That is a clean and simple Assembly, And I am selecting the viewas well.
Is that working with oyu?? Iam Using INV 2013.
Message 6 of 10
djreesing
Hmm last week it worked, but I now seem to get the same behavior you mention. Just an empty msgbox.
I will try to find out what the problem is.
Daniël
Message 7 of 10
djreesing
Ok, here's what I've found out.
When I place a view with a design view other than Master selected, the code works. If I select another design view other than master, the code also works. But if I select the master design view, the ActiveDesignViewRepresentation property returns an emptry string. Even more strange, when I now select another design view (which previously worked), the string is still empty!
Could you please check if you can reproduce this?
Message 8 of 10
ActiveDesignViewRepresentation  property works if and only Associative box is checked (marked) when placing the view on the drawing sheet.
But I am looking to get the name of the view even if assocative is not selected.
Even if there is a custom view (or Default View), without associative checked, msgbox result a null value.
May be somebody should fix or clarify.
Message 9 of 10
xiaodong_liang
this is a known issue which has been logged: ActiveDesignViewRepresentation  should return the corresponding view name no matter the view associative or not.
Message 10 of 10
Crstiano
in reply to: xiaodong_liang
Hi Xiaodong,
I have similar problem... my ActiveDesignViewRepresentation always returns = ""
Exist a correct way for control and change the DesignViewRepresentation of the SubAssembly in the Assembly?
I try in IV2014, if I use:
Call oOcc.SetDesignViewRepresentation ("OffZones")
 The software crash !!!!
If I use:
Dim oRepMan As RepresentationsManager
Set oRepMan = oOcc.Definition.RepresentationsManager
Dim oDVR As DesignViewRepresentation
Set oDVR = oRepMan.DesignViewRepresentations.Item("OffZones")
Call oDVR.Activate
 Don't show effects.... Smiley Frustrated
And another set: How define IsAssociativeToDesignViewRepresentation in this change ??
Thanks in advance
Cristiano Oliveira
Developer Addins | Consultant CAD/PLM | CAD Manager
https://www.ConsultCAD.com/
