First of all, my name is not Sanjay
I've tested it, and ActiveDesignViewRepresentation returns the name of the active design view. See example code below. It will let you select a view and then the name of the active design view is displayed in a messagebox.
Sub DesignViewRep() Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oDrawingView As DrawingView Set oDrawingView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select a drawing view") MsgBox oDrawingView.ActiveDesignViewRepresentation End Sub
Hope this helps.
Daniël
P.S. Next time please start a new discussion instead of cracking open one from years ago.
