Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Change a parameter that controls a feature's suppression (with iLogic/VBA!)
6 REPLIES 6
539 Views, 6 Replies
Hi everbody,
I've got an IPT with several features in it (extrsions, revolution, fillets ...).
Some of them are suppressed by a condition such as "suppress if parameter_A = 0".
I'd like to replace this "parameter_A" by "parameter_B" with the help of iLogic/VBA.
So I need to read-out the original parameter and then replace it with the correct new one.
However I'm stuck here not knowing how to do that.
It should have something to do with "GetSuppressionCondition" with I found somewhere.
But I don't know how to handle it.
Can anyone help me, please?
Regards
Heiko1985
6 REPLIES 6
wimann
I guess I'm a little confused as to what you're really wanting it to do.
So currently you have:
Suppress if Param_A = 0
I get that.
It's the replace Param_A by Param_B part that I'm not sure about... that sounds like you would just say:
Suppress if Param_B = 0
But if what you're going for is a swap when Param_A causes suppression then I'd say:
If Param_A = 0 then
Param_A = Param_B
else
End if
Is that what you're trying to do?
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
in reply to: wimann
Thank you for your reply.
To make things more precise:
I have an IPT which is made of several features, e. g. extrusions.
Some of theese are suppressed by a condition: Right click => Properties => Suppress if ...
Each extrusion has a different suppression condition. However, their parameters are all named in a specific way, such as: Parameter1_A, Parameter2_A, Parameter3_A and so on. So, they all end with "_A".
Now, I need to apply new parameters for all theese suppression conditions. The new parameters have the same name as the old ones, but they end with "_B". But there is no reference between "_A" and "_B". And since I have to publish a cleaned up IPT, I can't just say "Parameter1_A = Parameter1_B".
So, I want to do the following:
1. Check every single feature (resp. extrusion) for its suppression condition.
2. If there is a suppression condition, read-out its parameter. The parameter's name will be "Something_A".
3. Remove the original parameter and apply the new parameter, which is called "Something_B".
4. Delete the old parameter "Something_A" which is no longer been used.
I know how to handle parameters in the parameter list. My problem is how to get and apply the parameter in the suppression condition.
Phew, hope I could express myself ...
rjay75
This will replace the parameter names.
Note: There's no error checking to check if the parameter exists or the feature is valid.
Dim compDef As ComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim param As Inventor.Parameter
Dim compareType As ComparisonTypeEnum
Dim expr As Object
For Each feat As Object In compDef.Features
'param Cannot be null so set to first parameter.
param
= compDef.Parameters(1) If feat.GetSuppressionCondition(param, compareType, expr) Then If param.Name.EndsWith("_A") Then Dim newName As String = param.Name.Replace("_A", "_B") feat.SetSuppressionCondition(compDef.Parameters(newName), compareType, expr) End If End If Next
in reply to: rjay75
Thank you!
I had to edit it a bit and now it works very well - except for one issue.
Dim od As PartDocument
Set od = ThisApplication.ActiveDocument
Set compDef = od.ComponentDefinition
Dim expr As Object
Dim feat As PartFeature
For Each feat In compDef.Features
        oldName = param.Name
        If Mid(oldName, Len(oldName) - 1, Len(oldName)) = "_A" Then
            newName = Replace(oldName, "_A", "_B")
            'feat.SetSuppressionCondition(compDef.Parameters(newName), compareType, expr) '<= Error!
Next
I can now check if there is a suppression condition and in case read-out its parameter.
But I can't set the new parameter.
The line feat.SetSuppressionCondition(compDef.Parameters(newName), compareType, expr) gives me a syntax error and I don't know how to deal with it. 😞
rjay75
Here's a working version.
Dim expr As Variant
    Set param = compDef.Parameters(1)
        oldName = param.name
            feat.SetSuppressionCondition compDef.Parameters(newName), compareType, expr
Next
 In VBA the line
Should be:
in reply to: rjay75
Great! That's what I've been looking for. Thanks alot! 🙂
