I am using Inventor 2009 and I need to be able to override the CG values for models that are created to represent actual components that will be used in a 19" Rack assembly. I only need to model the outer casing and would like to input the known CG for the component to caluculate an assembly CG. I see that you can override the weight, but it looks like you can't override the CG. Does anyone know how to overrride the CG?
-Jeff
Edited by: jcaswall on Apr 2, 2009 5:38 PM
