Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
cannot add browser node to empty browser folder!
2 REPLIES 2
truscher
1401 Views, 2 Replies
I am trying to use the Browsernode.addchild method to add an occurence to an empty browser folder. The code fails at this point and I gett an error pointing to the line "Call oTargetNode.AddChild(oSourceNodeDef)". I can add the occurence with the browserpanes.Reorder method without issue if the folder is not empty. The code is pasted Below. Any help on this would be appreciated, as I am stumped. The code is both pasted below and attached Thanks in advance!
Code:
Format:HTML Format Version:1.0 StartHTML:     165 EndHTML:   29338 StartFragment:     314 EndFragment:   29306 StartSelection:     314 EndSelection:     314
SyntaxEditor Code Snippet
DimPrcsTpAsStringPrcsTp=InputListBox("Process Type?", MultiValue.List("ProcessType"), Parameter("ProcessType"), Title :="Select Process Type", ListName :="Process Type")DimRtgNameAsStringRtgName=PrcsTp&"-"&Parameter("NoRtgsInc")+1MessageBox.Show(RtgName, "Title",MessageBoxButtons.OKCancel)DimoAsmAsAssemblyDocument=ThisDoc.DocumentDimoMatrixAsMatrix=ThisApplication.TransientGeometry.CreateMatrixDimoOccAsComponentOccurrenceoOcc=oAsm.ComponentDefinition.Occurrences.AddVirtual(RtgName, oMatrix)DimoCompDefVirtualAsVirtualComponentDefinition=oOcc.Definition'CREATE AND SET THE IPROPDimoPropertySetAsPropertySet=oCompDefVirtual.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")oProperty=oPropertySet.Add(PrcsTp, "ProcessType")oProperty=oPropertySet.Add("", "SortOrder")oProperty=oPropertySet.Add("1", "BaanOrder")oProperty=oPropertySet.Add("", "Text1")oProperty=oPropertySet.Add("", "Text2")oProperty=oPropertySet.Add("", "Text3")oProperty=oPropertySet.Add("", "Text4")oProperty=oPropertySet.Add("", "Date1")oProperty=oPropertySet.Add("", "Date2")oProperty=oPropertySet.Add("", "Date4")oProperty=oPropertySet.Add("", "Notes")Parameter("NoRtgsInc")=Parameter("NoRtgsInc")+1DimoPaneAsBrowserPaneoPane=oAsm.BrowserPanes.Item("Model")DimoSourceNodeAsBrowserNodeoSourceNode=oPane.GetBrowserNodeFromObject(oOcc)DimoSourceNodeDefAsBrowserNodeDefinitionoSourceNodeDef=oSourceNode.BrowserNodeDefinition()DimoTopNodeAsBrowserNodeoTopNode=oPane.TopNode()DimoTopNodeOccAsBrowserFoldersEnumeratoroTopNodeOcc=oTopNode.BrowserFoldersDimoRTGNodeAsBrowserNodesEnumeratorDimoTargetNodeAsBrowserNodeDimoChildNodeAsBrowserNodeDimiAsLongDimiiAsLongFori=oTopNodeOcc.CountTo1Step-1IfoTopNodeOcc.Item(i).Name()="Routings"ThenoTargetNode=oTopNodeOcc.Item(i).BrowserNodeoRTGNode=oTargetNode.BrowserNodesii=oRTGNode.countIfii=0ThenCalloTargetNode.AddChild(oSourceNodeDef)'Call oPane.Reorder (oChildNode, False, oSourceNode)EndIfoChildNode=oRTGNode.Item(ii)CalloPane.Reorder(oChildNode, False, oSourceNode)EndIfNext
2 REPLIES 2
adam.nagy
in reply to: truscher
It seems to me that you would need to use BrowserFolder.Add instead of BrowserFolder.BrowserNode.AddChild
That worked fine for me from VBA:
Sub TestBrowserPane()
' Make sure you have a folder in the browser under the root node
' and then select one of the component occurrences in the model
Dim oAsm As AssemblyDocument
Set oAsm = ThisApplication.ActiveDocument
Dim oPane As BrowserPane
Set oPane = oAsm.BrowserPanes.Item("Model")
Dim oOcc As ComponentOccurrence
Set oOcc = oAsm.SelectSet(1)
Dim oSourceNode As BrowserNode
Set oSourceNode = oPane.GetBrowserNodeFromObject(oOcc)
Dim oSourceNodeDef As BrowserNodeDefinition
Set oSourceNodeDef = oSourceNode.BrowserNodeDefinition()
Dim oTopNode As BrowserNode
Set oTopNode = oPane.TopNode()
Dim oTopNodeOcc As BrowserFoldersEnumerator
Set oTopNodeOcc = oTopNode.BrowserFolders
Call oTopNodeOcc(1).Add(oSourceNode)
End Sub
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
freudeind
in reply to: adam.nagy
Hi, I need a little assitance with adding a broswer node to an existing folder. The programming help content does not address this.
The error I'm receiving:
Error on Line 24 : Reference to a non-shared member requires an object reference.
Sub Main()
oOcc = Component.InventorComponent("Source Occurence")
Dim oOcc1 As ComponentOccurrence
oOcc1 = Component.InventorComponent("Destination Occurence")
Dim oDestNode As BrowserNode
oDestNode = oPane.GetBrowserNodeFromObject(oOcc1)
Dim oDestNodeDef As BrowserNodeDefinition
oDestNodeDef = oDestNode.BrowserNodeDefinition()
Call BrowserFolder.Add(oSourceNode,oDestNode)
End Sub
