I've been struggling for a week to get this to work, but I can't get OnExecute to do anything. I've created a basic form that I can get to show up. I've also got a custom button that shows up as expected. When I add a Private Sub customButton_OnExecute() per Brian Ekins' tutorial, nothing happens when I click the button. Here's my code as of right now. I'm not sure where else to look for an answer for this. Any help of direction would be most appreciated.
Imports Inventor Imports System.Runtime.InteropServices Imports Microsoft.Win32 Imports System.Windows.Forms Imports System.Drawing Imports System.Drawing.Imaging Namespace iLogicPOC <ProgIdAttribute("iLogicPOC.StandardAddInServer"), _ GuidAttribute("51003206-914f-4244-8140-803c09a678bc")> _ Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer ' Inventor application object. Private m_InventorApplication As Inventor.Application = Nothing Public WithEvents customButton As ButtonDefinition = Nothing Private WithEvents m_uiEvents As UserInterfaceEvents = Nothing Private m_clientID As String = "{51003206-914f-4244-8140-803c09a678bc}" #Region "ApplicationAddInServer Members" Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate ' Save reference to the Application object in member variable. m_InventorApplication = addInSiteObject.Application ' Get a reference to the UserInterfaceManager object. Dim UIManager As Inventor.UserInterfaceManager = _ m_InventorApplication.UserInterfaceManager ' Get a reference to the ControlDefinitions object. Dim controlDefs As ControlDefinitions = _ m_InventorApplication.CommandManager.ControlDefinitions ' Get the images from the resources. They are stored as .Net images and the ' PictureConverter class is used to convert them to IPictureDisp objects, which ' the Inventor API requires. Dim smallPicture As stdole.IPictureDisp = _ PictureConverter.ImageToPictureDisp(My.Resources.rectffSml) Dim largePicture As stdole.IPictureDisp = _ PictureConverter.ImageToPictureDisp(My.Resources.rectffLrg) ' Create the button definition. customButton = controlDefs.AddButtonDefinition("RECTFF", "UIRibbonSampleOne", _ CommandTypesEnum.kNonShapeEditCmdType, _ m_clientID, , , smallPicture, largePicture) ' Call the function to add information to the user-interface. If firstTime Then CreateUserInterface() End If ' Connect to UI events to be able to handle a UI reset. m_uiEvents = m_InventorApplication.UserInterfaceManager.UserInterfaceEvents End Sub ' Creates the add-in’s UI in the ribbon. Private Sub CreateUserInterface() ' Get a reference to the UserInterfaceManager object. Dim UIManager As Inventor.UserInterfaceManager = _ m_inventorApplication.UserInterfaceManager ' Get the zero doc ribbon. Dim zeroRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("ZeroDoc") ' Get the getting started tab. Dim startedTab As Inventor.RibbonTab = zeroRibbon.RibbonTabs.Item("id_GetStarted") ' Get the new features panel. Dim newFeaturesPanel As Inventor.RibbonPanel newFeaturesPanel = startedTab.RibbonPanels.Item("id_Panel_GetStartedWhatsNew") ' Add a button to the panel, using the previously created button definition. newFeaturesPanel.CommandControls.AddButton(customButton, True) End Sub Private Sub customButton_OnExecute(ByVal Context As Inventor.NameValueMap) Dim mainForm As New Form1 mainForm.Show() End Sub Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate ' This method is called by Inventor when the AddIn is unloaded. ' The AddIn will be unloaded either manually by the user or ' when the Inventor session is terminated. ' TODO: Add ApplicationAddInServer.Deactivate implementation ' Release objects. m_InventorApplication = Nothing System.GC.Collect() System.GC.WaitForPendingFinalizers() End Sub Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation ' This property is provided to allow the AddIn to expose an API ' of its own to other programs. Typically, this would be done by ' implementing the AddIn's API interface in a class and returning ' that class object through this property. Get Return Nothing End Get End Property Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand ' Note:this method is now obsolete, you should use the ' ControlDefinition functionality for implementing commands. End Sub #End Region <System.ComponentModel.DesignerCategory("")> _ Friend Class PictureConverter Inherits System.Windows.Forms.AxHost Private Sub New() MyBase.New(String.Empty) End Sub Public Shared Function ImageToPictureDisp( _ ByVal image As System.Drawing.Image) As stdole.IPictureDisp Return CType(GetIPictureDispFromPicture(image), stdole.IPictureDisp) End Function End Class '' This property uses reflection to get the value for the GuidAttribute attached to the class. 'Public Shared ReadOnly Property AddInGuid(ByVal t As Type) As String ' Get ' Dim guid As String = "" ' Try ' Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False) ' Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute) ' guid = "{" + guidAttribute.Value.ToString() + "}" ' Finally ' AddInGuid = guid ' End Try ' End Get 'End Property End Class End Namespace
Solved by santoshr0114. Go to Solution.
You can use "ControlDefinition functionality for implementing commands."
Something like AddHandler _defComando1.OnExecute, AddressOf Command3Execute
Then have a method Command3Execute
Wooohoooo! It's good to see that working. I guess it just never clicked that I would need to add the event handler before I used it. I think I've been spoiled up to this point! Everything works as it is supposed to. Here's the code I added:
'Link the button objects with the event AddHandler customButton.OnExecute, AddressOf customButton_OnExecute
Here's all of the code in present form for the StandardAddInServer module:
Imports Inventor Imports System.Runtime.InteropServices Imports Microsoft.Win32 Imports System.Windows.Forms Imports System.Drawing Imports System.Drawing.Imaging Namespace iLogicPOC <ProgIdAttribute("iLogicPOC.StandardAddInServer"), _ GuidAttribute("51003206-914f-4244-8140-803c09a678bc")> _ Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer ' Inventor application object. Private m_InventorApplication As Inventor.Application = Nothing Public WithEvents customButton As ButtonDefinition = Nothing Private WithEvents m_uiEvents As UserInterfaceEvents = Nothing Private m_clientID As String = "{51003206-914f-4244-8140-803c09a678bc}" #Region "ApplicationAddInServer Members" Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate ' Save reference to the Application object in member variable. m_InventorApplication = addInSiteObject.Application ' Get a reference to the UserInterfaceManager object. Dim UIManager As Inventor.UserInterfaceManager = _ m_InventorApplication.UserInterfaceManager ' Get a reference to the ControlDefinitions object. Dim controlDefs As ControlDefinitions = _ m_InventorApplication.CommandManager.ControlDefinitions ' Get the images from the resources. They are stored as .Net images and the ' PictureConverter class is used to convert them to IPictureDisp objects, which ' the Inventor API requires. Dim smallPicture As stdole.IPictureDisp = _ PictureConverter.ImageToPictureDisp(My.Resources.rectffSml) Dim largePicture As stdole.IPictureDisp = _ PictureConverter.ImageToPictureDisp(My.Resources.rectffLrg) ' Create the button definition. customButton = controlDefs.AddButtonDefinition("My Button", "UIRibbonSampleOne", _ CommandTypesEnum.kNonShapeEditCmdType, _ m_clientID, , , smallPicture, largePicture) 'Link the button objects with the event AddHandler customButton.OnExecute, AddressOf customButton_OnExecute ' Call the function to add information to the user-interface. If firstTime Then CreateUserInterface() End If ' Connect to UI events to be able to handle a UI reset. m_uiEvents = m_InventorApplication.UserInterfaceManager.UserInterfaceEvents End Sub ' Creates the add-in’s UI in the ribbon. Private Sub CreateUserInterface() ' Get a reference to the UserInterfaceManager object. Dim UIManager As Inventor.UserInterfaceManager = _ m_inventorApplication.UserInterfaceManager ' Get the zero doc ribbon. Dim zeroRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("ZeroDoc") ' Get the getting started tab. Dim startedTab As Inventor.RibbonTab = zeroRibbon.RibbonTabs.Item("id_GetStarted") ' Get the new features panel. Dim newFeaturesPanel As Inventor.RibbonPanel newFeaturesPanel = startedTab.RibbonPanels.Item("id_Panel_GetStartedWhatsNew") ' Add a button to the panel, using the previously created button definition. newFeaturesPanel.CommandControls.AddButton(customButton, True) End Sub Private Sub customButton_OnExecute() Dim mainForm As New Form1 mainForm.Show() End Sub Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate ' This method is called by Inventor when the AddIn is unloaded. ' The AddIn will be unloaded either manually by the user or ' when the Inventor session is terminated. ' TODO: Add ApplicationAddInServer.Deactivate implementation ' Release objects. m_InventorApplication = Nothing System.GC.Collect() System.GC.WaitForPendingFinalizers() End Sub Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation ' This property is provided to allow the AddIn to expose an API ' of its own to other programs. Typically, this would be done by ' implementing the AddIn's API interface in a class and returning ' that class object through this property. Get Return Nothing End Get End Property Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand ' Note:this method is now obsolete, you should use the ' ControlDefinition functionality for implementing commands. End Sub #End Region <System.ComponentModel.DesignerCategory("")> _ Friend Class PictureConverter Inherits System.Windows.Forms.AxHost Private Sub New() MyBase.New(String.Empty) End Sub Public Shared Function ImageToPictureDisp( _ ByVal image As System.Drawing.Image) As stdole.IPictureDisp Return CType(GetIPictureDispFromPicture(image), stdole.IPictureDisp) End Function End Class End Class End Namespace
