I use:
oView.scale=oView.scale/2
to half each view scale. It works for base view, projected views like bottom view and left view, but it doesn't work for Isometric view. Which property should I use for Isometric view?
John
Solved by xiaodong_liang. Go to Solution.
Solved by pds. Go to Solution.
It works at my side. Please see the attached snapshot. If you still have the problem, could you share a small demo?
Hi XiaoDong,
It doesn't work when you select both normal view and ISOmetric view.
If you only select the ISOmetric view, it will work. I want all views change together no matter what kind of view they are.
Thanks for help
John
A short test video is attached. It works well at my side. Which version you are using? I used Inventor 2013 + SP1.1
