I need to know why the object collection and surfacbody value get this error in the watchlist right after performing a combine.
<Application-defined or object-defined error>
This doesn' always happen and I can't figure out why.
Option Explicit Dim oSurfBody As SurfaceBody Dim oCompDef As ComponentDefinition Dim oPartCompDef As PartComponentDefinition Dim oPartDoc As PartDocument Public Sub DeriveInterference() On Error GoTo error_checking Dim lngErr As Long Dim i As Long Dim oSurfBodies As SurfaceBodies Dim oRemoveSB As ObjectCollection Dim oTO As TransientObjects Set oTO = ThisApplication.TransientObjects 'Set o2CutSurfBodies = oTO.CreateObjectCollectionByVarian Set oRemoveSB = oTO.CreateObjectCollection Set oPartDoc = ThisApplication.ActiveDocument Set oPartCompDef = oPartDoc.ComponentDefinition Dim oSBInt As SurfaceBody Dim oSBCaut As SurfaceBody Dim oSBMain As SurfaceBody Set oSurfBodies = oPartCompDef.SurfaceBodies For Each oSurfBody In oPartCompDef.SurfaceBodies If oSurfBody.Name = "INT" Then Set oSBInt = oSurfBody ElseIf oSurfBody.Name = "CAUT" Then Set oSBCaut = oSurfBody ElseIf oSurfBody.Name = "Main" Then Set oSBMain = oSurfBody End If Next oSurfBody oSBInt.Visible = False oSBCaut.Visible = False oSBMain.Visible = False Call oRemoveSB.Add(oSBInt) Call oRemoveSB.Add(oSBMain) For i = 1 To oPartCompDef.SurfaceBodies.Count 'For Each oSurfBody In oPartCompDef.SurfaceBodies Set oSurfBody = oPartCompDef.SurfaceBodies.Item(i) Call CutCombine(oSurfBody, oRemoveSB) Next i 'Next oSurfBody error_checking: lngErr = Err.Number End Sub Public Sub CutCombine(sbBase As SurfaceBody, ocRemove As ObjectCollection) Dim oCombFeat As CombineFeature Dim oCombFeats As CombineFeatures If Not sbBase.Name = "INT" Or Not sbBase.Name = "CAUT" _ Or Not sbBase.Name = "Main" Then sbBase.Visible = True Set oCombFeats = oPartCompDef.Features.CombineFeatures Set oCombFeat = oCombFeats.Add _ (sbBase, ocRemove, kCutOperation, True) End If End Sub
