I looked at the help but you know it is no help for me LOL.
If you have an example it would be nice I am on 2012 still.
I am trying to get omething to work and it sounds like a case statement would work but seem not to understand it enough to get it to work LOL.
Maybe this helps:
http://www.dotnetperls.com/select-case-vbnet
The case statement is nothing more then I would say advanced If then Else statement.
You would check a variable for different values and state in every case that´s possible what to do.
Easy example would be a boolean which you would check for both values true and false.
Case True
'some vb code for this case
Case False
Of course you could do this with If then Else as well, but if you have more values for example from 1 to 6 you would need to check for every CASE possible e.g. 1,2,3,4,5,6.
All the best
Falk
Falk,
Thank you that gave some more understanding but still not grasping.
You say it is like a If...Then statement but all examples I have seen only return a value.
Can a case statement do things like turn on and of features?
Example:
I have a shaft with sprockets can be one or it can be 2,3,4,5 even more
I would like if numbers are odd sprocket is in center of shaft but more then 1 sprocket will move to off center and turn on a pattern to array the sprockets.
But also have an option if sprocket offset is equal (true) turns on one pattern if False turns 2 other patterns on.
Is this something a Case statement would be used for?
Thanks...
"Case Statement" is best used when you have to explicitly check the value of a variable:
Sub Sprockets() Dim Sprocket As Integer Sprocket = 1 'Explicitly check the value of the variable "Sprocket" Select Case Sprocket Case 1 MsgBox "Sprocket = " & Sprocket Case 2 MsgBox "Sprocket = " & Sprocket Case 3 MsgBox "Sprocket = " & Sprocket End Select 'You could also do a logic check on Sproket variable with select case Select Case Sprocket Case Is > 3 MsgBox "Sprocket = " & Sprocket Case Is < 2 MsgBox "Sprocket = " & Sprocket End Select 'But to do these logic check, If Then Statements are prefered in my opinion If Sprocket > 3 Then MsgBox "Sprocket = " & Sprocket ElseIf Sprocket < 2 Then MsgBox "Sprocket = " & Sprocket End If 'Therefore if you want to check if a value is odd or even I think it's best with If...Then Statement If CBool(Sprocket Mod 2) Then 'odd MsgBox "Sprocket is ODD" Else MsgBox "Sprocket is EVEN" End If 'Finaly, you could mix both If...Then and Select Case statements Dim Size_State As String Size_State = "Big" If CBool(Sprocket Mod 2) Then 'odd Select Case Size_State Case "Big" MsgBox "Sprocket is ODD and Big" Case "Small" MsgBox "Sprocket is ODD and Small" End Select Else Select Case Size_State Case "Big" MsgBox "Sprocket is EVEN and Big" Case "Small" MsgBox "Sprocket is EVEN and Small" End Select End If End Sub
Thank you that gave me some understanding.
Now what I see is it can only do messages with a case statement I cannot control features with it.
Am I correct?
Well I started with If... Then statements but seemed not to be able to get it to work so I started looking into case statements but nothing worked. I blamed that on my knowledge so that is why I asked.
I have not tried the case statement yet that is what I am doing now thanks to you and others.
As soon as I get something I will post with issues or post with IT WORKS LOL..
Going to just try something simple and if it works I will add the rest..
Thanks I will get back with you on the help Lord knows I need it...
Does the case statement work differnt in ilogic as to VB?
I am trying to get it to work with ilogic and I get error right off the bat.
Tells me Type " Interger " is not defined
Does this not define it?
Dim Number_Of_Sprockets As Interger Number_Of_Sprockets = 1
Can I use a parameter that is linked with an assembly using ilogic?
Just notice I spelled Integer wrong I changed it and have new error
"value" is not a member of "Integer"
Ok I have this so far.
Parameter("Sprocket_Count") = Number_Of_Sprocket Select Case Sprocket_Count Case 1 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = True Case 2 Feature.IsActive("Sprocket 1") = True Feature.IsActive("Sprocket 2") = True Feature.IsActive("Center Sprocket") = False Case >= 3 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = False Feature.IsActive("Center Multi") = True End Select
It does what is needed so far.
Question is there a way to link a and or andalso to it?
If there is 1 sprocket no issue it would be centered on the keyway in the shaft if the count is 2 the sprocket is offset no issue If the count is 3 the sprocket is centered on the keyway and pattern is turned on that is equal no issue.
The issue is when I have more then 4 sprockets the spacing may not be equal it may go 2" space then a 3" space . or if it has 6 it may not be equal spacing Is there a way for it to check two conditions and if meet do this?
And do I have to make a line of code for each range or can it be lumped into 1 to 2 statements
Like
Case 1
BLA BLA BLA
Case 2
BLA BLA
Case 3,7,9
BLA BLA BLA BLA
Or is there a way to tell it after this number and this is true do this?
I did put >= on the 3 just to test something but it will not work on even number of sprockets that was just to see what it would do..
Thanks..........
I tried to add this to handle my issue but "Mod 2" seems to stop it from working.
Parameter("Sprocket_Count") = Number_Of_Sprocket Select Case Sprocket_Count Case 1 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = True Feature.IsActive("Center Multi") = False Feature.IsActive("Center Pattern") = False Case 2 Feature.IsActive("Sprocket 1") = True Feature.IsActive("Sprocket 2") = True Feature.IsActive("Center Sprocket") = False Case (Sprocket_Count Mod 2) >= 3 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = False Feature.IsActive("Center Multi") = True Feature.IsActive("Center Pattern") = True Case (Sprocket_Count Mod 2) >= 4 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = False Feature.IsActive("Center Multi") = False Feature.IsActive("Center Pattern") = False End Select
Ok I added a few things works so far..
Only need to find out if you can have a 2 condition met do this.
Here is what I have so far..
Parameter("Sprocket_Count") = Number_Of_Sprocket Select Case Sprocket_Count Case 1 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = True Feature.IsActive("Center Multi") = False Feature.IsActive("Center Pattern") = False Case 2 Feature.IsActive("Sprocket 1") = True Feature.IsActive("Sprocket 2") = True Feature.IsActive("Center Sprocket") = False Case 3,5,7,9,11,13,15,17,19 Feature.IsActive("Sprocket 1") = False Feature.IsActive("Sprocket 2") = False Feature.IsActive("Center Sprocket") = False Feature.IsActive("Center Multi") = True Feature.IsActive("Center Pattern") = True Case 4,6,8,10,12,14,16,18,20 Feature.IsActive("Sprocket 1") = True Feature.IsActive("Sprocket 2") = True Feature.IsActive("Center Sprocket") = False Feature.IsActive("Center Multi") = False Feature.IsActive("Center Pattern") = False End Select
Thanks.......
Oh I see I thought it would carry like
Mod 2 = 1 would do 3,5,7,9 etc..
Mod 2 = 2 would do 4,6,8,10 etc.
Any thought on the true/false for equal and none equal spacing?
I tried
Case 2 andalso Sprocket_Equal_Spacing = True
But it also did nothing..
Many Thanks
