I've read lots of posts with no answers and was wondering, is it possible to call up an iLogic form via the API?
I have an iLogic form which is in a part. That part is in an assembly which gets called up on an IDW.
So the structure looks like this: IDW > IAM > IPT : Form
I want to be able to call that form up from the IDW using a rule as iLogic / Pure vb.net either is fine.
Autodesk guys, if this is not possible please let me know, I have tried lots of workarounds to try and get it to work but nothing has worked.
Any help is much appreciated.
Thanks, Matt.
Windows 7 | Inventor Pro 2012
Solved by matt_jlt. Go to Solution.
Ok, found a solution (mostly due to an old post i found on the subject). I'll post it here for anyone interested.
In the IDW level I have a rule that gets reference to the part document from a view and executes a rule inside that that runs the form.
Public Sub Main() ' Get iLogic Addin Dim iLogicAuto As Object = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub ' Get reference document Dim oRefDoc As Document = ActiveSheet.View("ViewName").ModelDocument ' Run rule iLogicAuto.RunRule(oRefDoc, "Rule - Run Form") End Sub Function GetiLogicAddin(oApplication As Inventor.Application) As Object ' Get addin collection & addin variables Dim addIns As ApplicationAddIns = oApplication.ApplicationAddIns Dim addIn As ApplicationAddIn Dim customAddIn As ApplicationAddIn For Each addIn In addIns If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then customAddIn = addIn Exit For End If Next If (customAddIn Is Nothing) Then Exit Function customAddIn.Activate Return customAddIn.Automation End Function
Regards, Matt.
