Inventor Customization
matt_jlt
Message 1 of 2 (574 Views)
Call iLogic Form Via API
574 Views, 1 Replies
02-06-2013 02:28 PM
I've read lots of posts with no answers and was wondering, is it possible to call up an iLogic form via the API?
I have an iLogic form which is in a part. That part is in an assembly which gets called up on an IDW.
So the structure looks like this: IDW > IAM > IPT : Form
I want to be able to call that form up from the IDW using a rule as iLogic / Pure vb.net either is fine.
Autodesk guys, if this is not possible please let me know, I have tried lots of workarounds to try and get it to work but nothing has worked.
Any help is much appreciated.
Thanks, Matt.
Windows 7 | Inventor Pro 2012
matt_jlt
Message 2 of 2 (564 Views)
Re: Call iLogic Form Via API
02-06-2013 05:51 PM in reply to: matt_jlt
Ok, found a solution (mostly due to an old post i found on the subject). I'll post it here for anyone interested.
In the IDW level I have a rule that gets reference to the part document from a view and executes a rule inside that that runs the form.
Public Sub Main()
	' Get iLogic Addin
    Dim iLogicAuto As Object = GetiLogicAddin(ThisApplication)
    If (iLogicAuto Is Nothing) Then Exit Sub
	' Get reference document
	Dim oRefDoc As Document = ActiveSheet.View("ViewName").ModelDocument
	' Run rule
	iLogicAuto.RunRule(oRefDoc, "Rule - Run Form")
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
	' Get addin collection & addin variables
  Dim addIns As ApplicationAddIns = oApplication.ApplicationAddIns
  Dim addIn As ApplicationAddIn
  Dim customAddIn As ApplicationAddIn
  For Each addIn In addIns
    If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
    	customAddIn = addIn
    Exit For
    End If
  Next
  If (customAddIn Is Nothing) Then Exit Function
  customAddIn.Activate
  Return customAddIn.Automation
End Function
 Regards, Matt.
