I wish to trap this function in the frame generator in order to rename the file/part number on the newly created member.
I cannot 'trap' it in the usual way by using FILEUIEVTS_ONPOPULATEFILEMETADATA, is there any other way I can get to this command to rename the new part that is being created?
Many thanks
Dave
Hi Dave,
Could you please list the exact steps in the UI that you'd like to automate?
I'm not sure what the Break reuse is. I can see the command reuse - is that what you mean?
Cheers,
Hi Adam - I think he means this command - RMB on a single frame member that has been reused.
Luke
Thanks Luke! 🙂
Dave's other post put me on the right track: http://forums.autodesk.com/t5/inventor-customization/frame-generator-command-quot-break-reuse-member...
