Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
BomView Error (any Autodesk employee's got a answer)
5 REPLIES 5
788 Views, 5 Replies
First off I have a Assembly File Open and  LOD set to "Mod" and I want to see the BomView for
Structured and I know you can only see the Structured Bom in LOD set to master. so I open another instance of the document (invisibly) in the Master representation and run code then I close the Document that I just opened invisible.
every thing works fine, then I do the same thing all over again and sometimes it works some times it throws an error and some times Inventor dies..so what is going on this this...see code below... and just FYI if I dont close the invisible Document then I can run the code over and over and over with no error..but I dont want to keep the invisible document open after i'm done with it..
Public Sub BomTest(ByVal InventorApp As Inventor.Application, ByVal oAssDoc As AssemblyDocument)
        Dim oAssemlyDocument As AssemblyDocument = Nothing
        Dim oAsmDocMasterLOD As AssemblyDocument = Nothing
        If InventorApp.ActiveEditDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            oAssemlyDocument = InventorApp.ActiveEditDocument
        Else
            oAssemlyDocument = oAssDoc
        Try
            If oAssemlyDocument.Dirty Then
                MsgBox("You Need to save the Assembly File First!")
                oAssemlyDocument = Nothing
                Exit Sub
        Catch ex As Exception
            MsgBox(ex.ToString)
        End Try
        Dim bClose As Boolean = False
        If oAssemlyDocument.LevelOfDetailName = "Master" Then
            oAsmDocMasterLOD = oAssemlyDocument
        Else
            Try
                oAsmDocMasterLOD = InventorApp.Documents.Open(oAssemlyDocument.File.FullFileName, False)
                bClose = True
                bClose = False
                MsgBox(ex.ToString)
            End Try
        If oAsmDocMasterLOD IsNot Nothing Then
            Dim m_oBOM As BOM = oAsmDocMasterLOD.ComponentDefinition.BOM
            m_oBOM.StructuredViewEnabled = True
            m_oBOM.StructuredViewFirstLevelOnly = False
            m_oBOM.StructuredViewDelimiter = "."
            Dim m_oBOMView As BOMView = Nothing
            Try
                For Each oview As BOMView In m_oBOM.BOMViews
                    If oview.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then
                        Try
                            m_oBOMView = oview
                            MsgBox("1. Error hit here")
                            m_oBOMView = Nothing
                        End Try
                        Exit For
                Next
                MsgBox("2. Error hit here")
            End Try
            If m_oBOMView IsNot Nothing Then
                Dim oBOMRows As Inventor.BOMRowsEnumerator = Nothing
                Try
                    oBOMRows = m_oBOMView.BOMRows
                    MsgBox("3. Error hit here")
                    oBOMRows = Nothing
                End Try
                If oBOMRows IsNot Nothing Then
                    For Each row As Inventor.BOMRow In oBOMRows
                        Try
                            Dim sItemNumber As String = row.ItemNumber
                            MsgBox("4. Error hit here")
                            Exit For
                        End Try
                    Next
            If bClose = True Then
                oAsmDocMasterLOD.Close(True)
        oAsmDocMasterLOD = Nothing
    End Sub
5 REPLIES 5
so no one knows why this crashes?
Vladimir.Ananyev
Could you please test Document.ReleaseReference method instead of Close method.
From API help:
This method  releases the reference that gets added if a document is opened invisibly through the API. Releasing the reference on a hidden document makes it a candidate for closure the next time Inventor closes all unreferenced documents.
Let us know the result please.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
in reply to: Vladimir.Ananyev
That does stop the Error, thank you..but now i'm unable to save the current assembly. please see attached file
Vladimir.Ananyev
Is SaveAll command suitable in your workflow?  If yes then you may try the following code
Dim oCommandMgr As CommandManager = oApp.CommandManager
Dim oControlDef As ControlDefinition = oCommandMgr. _
    ControlDefinitions.Item("AppSaveAllCmd")
'oApp.SilentOperation = True
Call oControlDef.Execute()
'oApp.SilentOperation = False
Vladimir Ananyev
thank you for your time spent looking in to this. All i'm really trying to do is access the Master Bill of Material so I decided to go with changing the LOD to Master is Needed. see code below. FYI i'm using Inventor 2012
        If InventorApp Is Nothing Then
            Exit Sub
        If oAssDoc Is Nothing Then
            Exit Sub
            If oAssDoc IsNot InventorApp.ActiveEditDocument Then
                MsgBox("This Program was designed not to work in edit mode", MsgBoxStyle.Exclamation, InventorApp.Caption)
                Exit Sub
        Try
            If oAssDoc.Dirty Then
                MsgBox("The assembly must be saved before performing the Bill of Materials" & vbCrLf & "operation.", MsgBoxStyle.Exclamation, InventorApp.Caption)
                Exit Sub
            MsgBox(ex.ToString)
        End Try
        Dim oCurrentLOD As LevelOfDetailRepresentation = Nothing
        Dim oRepMgr As RepresentationsManager = oAssDoc.ComponentDefinition.RepresentationsManager
        oCurrentLOD = oRepMgr.ActiveLevelOfDetailRepresentation
        InventorApp.StatusBarText = "Accessing Master Level Of Detail"
        InventorApp.ScreenUpdating = False
        Try
            If oAssDoc.LevelOfDetailName <> "Master" Then
                Dim oMasterLOD As LevelOfDetailRepresentation = oRepMgr.LevelOfDetailRepresentations.Item("Master")
                oMasterLOD.Activate(True)
            oCurrentLOD = Nothing
        End Try
            MsgBox("The Level Of Detail needs to be set to Master!")
        Else
            Try
                Dim m_oBOM As BOM = oAssDoc.ComponentDefinition.BOM
                        m_oBOMView = oview
                Next
                    Dim oBOMRows As Inventor.BOMRowsEnumerator = m_oBOMView.BOMRows
                        Next
                MsgBox("Unknown Error")
            End Try
        If oCurrentLOD IsNot Nothing Then
            If oRepMgr.ActiveLevelOfDetailRepresentation IsNot oCurrentLOD Then
                oCurrentLOD.Activate(True)
        InventorApp.ScreenUpdating = True
        oAssDoc = Nothing
    End Sub
