I'm going to Vault Professional 2012 all files of the company and as I need the assemblies have a specific BOM (for when you get on and connect to SAP Item) I created a program that uses Windows API to import from every assembly a BOM custom XML file (Because, incredibly, the Inventor API does not expose functions to import and export custom BOM)
One of the new columns is a custom iProperty need to be completed by programming (I have to copy the numbers that are in ITEM, and lost in Vault Item when passed and there are several files with the same ID)
You can write in a ROW CELL a list of materials?
Is there any function or similar type = <ID> allow me to put the numbers in this cell is in the field Element (ID or Item)
Thank you.
