Inventor Customization
Active Contributor
montylowe
Message 1 of 5 (334 Views)
BOM uppdate on drawing
334 Views, 4 Replies
03-31-2011 12:04 PM
Having issues with my BOM not updating on my drawing after assembly has changed. Also I would like to make sure it stays sorted. I have a drawing templete the houses several views and an assembly that is changed via VB but when I open the drawing the views are updated but BOM is not. I have to do and edit and sort for the correct values to appear.
Thanks in advance.
Active Contributor
montylowe
Message 2 of 5 (319 Views)
Re: BOM uppdate on drawing
04-04-2011 04:36 AM in reply to: montylowe
Does anyone have any light to shed or code to share regarding this Post? Thank
Active Contributor
montylowe
Message 3 of 5 (285 Views)
04-12-2011 07:42 AM in reply to: montylowe
OK maybe I haven't explained this very well. After I undate a assembly model I open the drawing and the BOM that I have on the drawing is not updated to the changeas that I have made only after I double pick the BOM and then close it does it reflect my changes is there a way to update iths thru the API
I hope someone can shed some light.
alewer
Message 4 of 5 (278 Views)
04-12-2011 09:00 AM in reply to: montylowe
Use the DrawingDocument.Update method.
Active Contributor
montylowe
Message 5 of 5 (255 Views)
04-13-2011 05:34 AM in reply to: alewer
Found what I needed in the folowing Post.
By sorting the PartsList it Updates to current values
http://forums.autodesk.com/t5/Autodesk-Inventor/Parts-list-sorting/m-p/2767648
