Is there any way to find out whether a BOM row parent is of type BOMView or BOMRow?
Thank you.
Solved by adam.nagy. Go to Solution.
Forgot to mention what programming language you are using, which the answer depends on.
For the main two: in VB it would be "If TypeOf myObject Is BOMView Then" in C# it would be if (myObject is BOMView) { } "
I hope this helps,
