we are doing a customization in inventor 2012 using vb.net as development language. The app is deployed in customer place and is working fine as programmed.
However the correct usage of application is dependent on custom tab in iProperty. If user manually makes changes in iproperty then application will work incorrectly; if managed through application application works fine.
This typical customer makes change in Custom tab in iproperty and works in through addin application which will definitely produce improper result.
My question is, Is it possible to restrict user from going to custom tab in iproperties.
Any help would be greatly appreciated
regards
Amit
Senior Software Engineer
