Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Bend line projection on a sketch
1 REPLY 1
denis.bourasseau
640 Views, 1 Reply
Hello.
Just by selecting a bend line on the flat pattern, I'd like to draw only 2 lines on a sketch (without any border projection, only points) at both ends of the bend line.
I'm sure it can be done via VBA, but don't know how to start for it.
Any idea?
1 REPLY 1
OK, I got it:
Sub Marquages()
Dim oPartDoc As PartDocument
Dim oPoint1, oPoint2 As Point2d
Set oPartDoc = ThisApplication.ActiveDocument
Dim oSheetMetalDef As SheetMetalComponentDefinition
Set oSheetMetalDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oFlatPattern As FlatPattern
Set oFlatPattern = oSheetMetalDef.FlatPattern
If oPartDoc.SelectSet.Count = 0 Then
    MsgBox "Selectionner un axe de pliage", vbExclamation
    End
End If
Dim oBendEdge As Edge
Set oBendEdge = oPartDoc.SelectSet(1)
Dim oSketch As PlanarSketch
Set oSketch = oFlatPattern.Sketches.Add(oSheetMetalDef.FlatPattern.TopFace, False)
oSketch.Name = "Marquages " & oFlatPattern.Sketches.Count
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
Dim oLines(1 To 3) As SketchLine
Set oLines(1) = oFlatPattern.Sketches(1).AddByProjectingEntity(oBendEdge)
Set oPoint1 = oLines(1).Geometry.StartPoint
Set oPoint2 = oLines(1).Geometry.EndPoint
Set oLines(2) = oSketch.SketchLines.AddByTwoPoints(oPoint1, oPoint2)
Call oSketch.GeometricConstraints.AddGround(oLines(2).StartSketchPoint)
Call oSketch.DimensionConstraints.AddTwoPointDistance(oLines(2).StartSketchPoint, oLines(2).EndSketchPoint, kAlignedDim, oPoint1)
oSketch.DimensionConstraints(1).Parameter.Value = 1
Set oLines(3) = oSketch.SketchLines.AddByTwoPoints(oPoint1, oPoint2)
Call oSketch.GeometricConstraints.AddGround(oLines(3).EndSketchPoint)
Call oSketch.DimensionConstraints.AddTwoPointDistance(oLines(3).StartSketchPoint, oLines(3).EndSketchPoint, kAlignedDim, oPoint2)
oSketch.DimensionConstraints(2).Parameter.Value = 1
Call oSketch.GeometricConstraints.AddCollinear(oLines(2), oLines(3))
oLines(1).Delete
End Sub
