When a Basic Tolerance is used to dimension - can the size of the containing box be adjusted?
I understand this is set as a percentage of the text size - where is this value & can it be edited?
MES
HI,
Did you ask in the Product Support forum as well?
If this setting is not available in the UI then there is no API for it either. 😞
Cheers,
