Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Balloon Text Color
1 REPLY 1
623 Views, 1 Reply
Balloon Text Color
I have iLogic code that cycles through all balloons on a drawing and finds any overridden values. What I need to do is change the balloon text color ONLY on the specific balloons that have been overridden. Any help?
1 REPLY 1
philippe.leefsma
Here is a sample extracted from the API Help files, it's VBA and it illustrates how to cycle all balloons and override their value:
Public Sub EditBalloons()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim BalloonCount As Long
    BalloonCount = 1
    Dim oBalloon As Balloon
    ' Iterate over each balloon on the sheet.
    For Each oBalloon In oSheet.Balloons
        ' Change the balloon type
        oBalloon.SetBalloonType (kHexagonBalloonType)
        ' Change balloon placement direction so all the attached
        ' balloons are placed to the right of the previous ones.
        oBalloon.PlacementDirection = kBottomDirection
        Dim ValueSetCount As Long
        ValueSetCount = 1
        Dim oBalloonValueSet As BalloonValueSet
        ' Iterate over each value set (attached balloons) in a balloon.
        For Each oBalloonValueSet In oBalloon.BalloonValueSets
            ' Change the override value.
            oBalloonValueSet.OverrideValue = "Balloon" & BalloonCount & ": ValueSet" & ValueSetCount
            ValueSetCount = ValueSetCount + 1
        Next
        BalloonCount = BalloonCount + 1
    Next
End Sub
By checking the BalloonValueSet.Static property you can determine if the balloon has been overriden. But I suspect from your description that you already know that...
I don't think you can change the color of a balloon, but you can set the layer it belongs to and set the color of that layer. Here is an another example that illustrates how to move entities to a new layer:
Public Sub Layer()
    'Set a reference to the drawing view.
    Dim oDraftView As DrawingView
    Set oDraftView = oDrawDoc.ActiveSheet.DrawingViews.AddDraftView(1#, "My Draft View")
    ' Set a reference to the sketch of the created draft view.
    Dim oSketch As DrawingSketch
    Set oSketch = oDraftView.Sketches.Item(1)
    ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    ' Draw four sketch lines that form a rectangle
    Call oSketch.SketchLines.AddAsTwoPointRectangle(oTransGeom.CreatePoint2d(10, 10), _
                                                oTransGeom.CreatePoint2d(30, 30))
    ' Draw four sketch circles
    Dim oSketchCircles(1 To 4) As SketchCircle
    Set oSketchCircles(1) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(12, 12), 1.5)
    Set oSketchCircles(2) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(28, 12), 1.5)
    Set oSketchCircles(3) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(12, 28), 1.5)
    Set oSketchCircles(4) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(28, 28), 1.5)
    ' Create a new layer (as a copy of the 'Sketch Geometry' layer)
    ' to put the sketch circles in.
    Dim oNewLayer As Layer
    Set oNewLayer = oDrawDoc.StylesManager.Layers.Item("Sketch Geometry (ANSI)").Copy("Custom Sketch Circles")
    ' Set the LineType on the new layer to 'dashed'.
    oNewLayer.LineType = kDashedLineType
    'Put all the sketch circles on this layer
    oSketchCircles(1).Layer = oNewLayer
    oSketchCircles(2).Layer = oNewLayer
    oSketchCircles(3).Layer = oNewLayer
    oSketchCircles(4).Layer = oNewLayer
    ' Turn off the new layer
    oNewLayer.Visible = False
    ' Exit from editing the sketch.
    oSketch.ExitEdit
End Sub
Hope this helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
