I have iLogic code that cycles through all balloons on a drawing and finds any overridden values. What I need to do is change the balloon text color ONLY on the specific balloons that have been overridden. Any help?
Here is a sample extracted from the API Help files, it's VBA and it illustrates how to cycle all balloons and override their value:
Public Sub EditBalloons() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the active sheet. Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet Dim BalloonCount As Long BalloonCount = 1 Dim oBalloon As Balloon ' Iterate over each balloon on the sheet. For Each oBalloon In oSheet.Balloons ' Change the balloon type oBalloon.SetBalloonType (kHexagonBalloonType) ' Change balloon placement direction so all the attached ' balloons are placed to the right of the previous ones. oBalloon.PlacementDirection = kBottomDirection Dim ValueSetCount As Long ValueSetCount = 1 Dim oBalloonValueSet As BalloonValueSet ' Iterate over each value set (attached balloons) in a balloon. For Each oBalloonValueSet In oBalloon.BalloonValueSets ' Change the override value. oBalloonValueSet.OverrideValue = "Balloon" & BalloonCount & ": ValueSet" & ValueSetCount ValueSetCount = ValueSetCount + 1 Next BalloonCount = BalloonCount + 1 Next End Sub
By checking the BalloonValueSet.Static property you can determine if the balloon has been overriden. But I suspect from your description that you already know that...
I don't think you can change the color of a balloon, but you can set the layer it belongs to and set the color of that layer. Here is an another example that illustrates how to move entities to a new layer:
Public Sub Layer() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the drawing view. Dim oDraftView As DrawingView Set oDraftView = oDrawDoc.ActiveSheet.DrawingViews.AddDraftView(1#, "My Draft View") ' Set a reference to the sketch of the created draft view. Dim oSketch As DrawingSketch Set oSketch = oDraftView.Sketches.Item(1) ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry Set oTransGeom = ThisApplication.TransientGeometry ' Draw four sketch lines that form a rectangle Call oSketch.SketchLines.AddAsTwoPointRectangle(oTransGeom.CreatePoint2d(10, 10), _ oTransGeom.CreatePoint2d(30, 30)) ' Draw four sketch circles Dim oSketchCircles(1 To 4) As SketchCircle Set oSketchCircles(1) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(12, 12), 1.5) Set oSketchCircles(2) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(28, 12), 1.5) Set oSketchCircles(3) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(12, 28), 1.5) Set oSketchCircles(4) = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(28, 28), 1.5) ' Create a new layer (as a copy of the 'Sketch Geometry' layer) ' to put the sketch circles in. Dim oNewLayer As Layer Set oNewLayer = oDrawDoc.StylesManager.Layers.Item("Sketch Geometry (ANSI)").Copy("Custom Sketch Circles") ' Set the LineType on the new layer to 'dashed'. oNewLayer.LineType = kDashedLineType 'Put all the sketch circles on this layer oSketchCircles(1).Layer = oNewLayer oSketchCircles(2).Layer = oNewLayer oSketchCircles(3).Layer = oNewLayer oSketchCircles(4).Layer = oNewLayer ' Turn off the new layer oNewLayer.Visible = False ' Exit from editing the sketch. oSketch.ExitEdit End Sub
Hope this helps,
Philippe.
