Backspace issue in addin form window
fakeru
fakeru
I have a window form from an addin, there I type some text in a textbox. When I hit backspace key, another instance of the form is invoked.
I really don't want this, it is annoying. I know the backspece key will call the last command in Inventor and that's ok for me. But that should not be the case when you type some text.
Is it possible to fix the issue?
Autodesk Inventor 2015 Certified Professional
fakeru
Actually it's not the backspace but the spacebar key and I have found the solution to this problem here
' myForm.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND)
