i try to do this:
ThisApplication.Documents.Open("XYZ.ipt")
but the file should open in the background. Not as the active document.
Then i want to save this Document in the background as a step (using the snippet)
' Set reference to active document.
oDoc = ThisApplication.ActiveDocument
' Check the Document type is an assembly or part
If (oDoc.DocumentType <> kAssemblyDocumentObject And _
oDoc.DocumentType <> kPartDocumentObject) Then
MsgBox("Error:Document type is not assembly/part")
Exit Sub
' Get document's full file name
sFname = ThisDoc.PathAndFileName(False) & ".sat"
' Do a 'Save Copy As' to SAT format
oDoc.SaveAs(sFname, True)
But in my case oDoc isn't the active document. How can i use the "inactive" document in the background?
I looked in the help files but found nothing about this case!
