Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Autoproject edges during curve creation
7 REPLIES 7
Message 1 of 8
cparnell
616 Views, 7 Replies
Does anyone know how to assign an keyboard shortcut to the, "Applications Options/Sketch/Autoproject edges during curve creation" setting?
I have a need to turn this on and off on a regular basis.
I have searched this forum and have found nothing that has delth with this.
7 REPLIES 7
Message 2 of 8
cparnell
in reply to: cparnell
By the way I relize that once a face is selected to sketch on that I can RMB and select Project Geometry, that is while in the sketch environment. I would like to be able to try a keyboard short cut to do the same thing.
Message 3 of 8
Robert..F
You can create a macro in your application project like this:
Public Sub AutoEndgeProject()
    Dim oSketchOptions As SketchOptions
    Set oSketchOptions = ThisApplication.SketchOptions
    Dim b As Boolean
    b = False
    If Not oSketchOptions.AutoProjectEdges Then b = True
    oSketchOptions.AutoProjectEdges = b
End Sub
 Then you can apply a keyboard shotcut to it by clicking Tools->Customize going to the keyboard tab.  Select macros in the Categories drop down.  Find your macro in the list and then choose your keyboard shotcut
Message 4 of 8
cparnell
in reply to: Robert..F
Robert:
This is great and I got a keyboard short cut to work, however the routine changes the "Autoproject edges during curve creation" rather than "Autoproject edges for sketch creation and edit".
Message 5 of 8
cparnell
Robert:
I just realized that my title was in reference to "Autoproject edges during curve creation" rather than "Autoproject edges for sketch creation and edit" which is what I wanted to do.
My bad.
Message 6 of 8
Robert..F
Change oSketchOptions.AutoProjectEdges to oSketchOptions.AutomaticReferenceEdges
Message 7 of 8
cparnell
Robert:
Thank you, that worked.
Message 8 of 8
Robert..F
You're welcome.  Glad I could help.
