I need to be able to add external rules to the external rules list without any user interaction.
Is there an XML file (other other editable file type) hiding somwhere that contains the list of external rules for me to edit?
Or is there a method in iLogicAutomation that do this?
I suspect the answer is no, and that it can't be done (yet!)
Cheers,
Tom
Solved by thomaskennedy. Go to Solution.
Didn't realise I could use a direct path to the rule just using RunExternalRule(path)
For me, that's probably a better solution than trying to add it to the list.
