Hi all.
The company I work for uses templates for our casting and machine drawings.
I'm wondering if there is a way to auto-fill some boxes on our template, most notably Author (works, but defaults to username of comp, not initials), and Scale (pulls scale from first drawing placed only).
Author uses the <DESIGNER> tag, and the Scale uses a custom tag in the iProperties menu. Company uses Inv. 2012.
Thanks in advance for the help.
Solved by matt_jlt. Go to Solution.
Solved by jdkriek. Go to Solution.
The CAD Admin should have had users configure thier Tools > Application Options > General Tab > "Username" to be the user's intials. Then when a new file is created the Author and Designer iProperties are automaticly filled in correctly. Then it's filled out on the title block automaticly via <AUTHOR> or <DESIGNER> variables inserted from Drawing Properties.
If you want your scale iproperty fille out automatically from the first view placed you can use iLogic / VBA / Addin.
For iLogic you can use this:
' Define Document & First Sheet Dim oDrg As DrawingDocument = ThisDrawing.Document Dim oSheet As Sheet = oDrg.Sheets.Item(1) ' Check if there are any views on the sheet If oSheet.DrawingViews.Count = 0 Then Exit Sub End If ' Get the first view on the sheet Dim oView As DrawingView = oSheet.DrawingViews.Item(1) ' Update Scale iProperty iProperties.Value("Custom", "Scale") = oView.ScaleString ' Update Drawing to reflect changes InventorVb.DocumentUpdate()
Just set the rule to run every time the drawing is saved
Inventor > Manage Tab > iLogic Panel > Event Triggers button
Regards, Matt.
If this solves your problem, please accept this as the solution.
Hi Matt,
How do you stop the code from overwriting a value (back to the scale of the first view inserted) if you have changed the scale manually?
Is there a code which reads whether a field has had a value inserted manually?
I'm sure there is other basic code which could achieve the same result, but I am new to this coding game so not too sure.
Cheers,
Nick
