Hello all , please help , running out of hair.....
What i'm trying to do is author three I beams (settings within ipart) for use in frame generator
Have been through this tutorial
https://www.youtube.com/watch?v=XOwR89pA_e8 and a few other white papers just to learn up
This problem is as follows:
When i click on "strutural shape authoring" i sellect I beams (auto completes "default base point etc") then select "paremeter mapping"
Select "base length" and and set as length BUT IT WONT CHANGE EXTRUSION TO BODY AND DRIVEN LENGTH
Hence i end up with a part not a profile for use in fame generator
Any help very greatly recieved!
Thanks all!
JD
Solved by jidickson. Go to Solution.
Spoke with a desiging guru type chap who came in , ran through my process, confirmed that i'm doing nothing wrong and also confirmed that IV is half arsed software at best
If i look through my prvious problems with IV it really does beggar belief that people pay for it
Problem solved by giving £7000 to a nice man from solid works
