I'm writing a program which attached a balloon to an existing balloon, such as the inventor command "Attach balloon"
i'm almost there: User selects an existing balloon and a component and gives a direction to draw the balloon and then the balloon is created fine.
The only problem is that i can't connect my balloon to the base balloon. So when i move the base balloon the attached balloon doesn't move with it.
Does anybody know how to do this?
Geert
Code: (is part of a larger Auto ballooning program)
PrivateSub CreateAttachBalloon(ByVal oBalloon As Inventor.Balloon)
Try
Dim oDrawDoc As Inventor.DrawingDocument
oDrawDoc = m_inventorApplication.ActiveDocument
Dim oActiveSheet As Inventor.Sheet
oActiveSheet = oDrawDoc.ActiveSheet
Dim oDrawingCurveSegment As Inventor.DrawingCurveSegment
Dim oSelect AsNew clsSelect
oDrawingCurveSegment = oSelect.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter,
"Select curve in highlighted component!", Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter)
Dim oDrawingCurve As Inventor.DrawingCurve
oDrawingCurve = oDrawingCurveSegment.Parent
Dim oTG As Inventor.TransientGeometry
oTG = m_inventorApplication.TransientGeometry
Dim oLeaderPoints As Inventor.ObjectCollection
oLeaderPoints = m_inventorApplication.TransientObjects.CreateObjectCollection
Dim dBalloonDiameter AsDouble
dBalloonDiameter = oBalloon.Style.BalloonDiameter
'user must give direction where to create the balloon
Dim Direction AsInteger
Dim oMouseEvent AsNew MouseEvents(oBalloon)
DoWhile oMouseEvent.isDone = False
m_inventorApplication.UserInterfaceManager.DoEvents()
Direction = oMouseEvent.Direction
Loop
' Create balloon center point.
Select Case Direction
Case 0
Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X + dBalloonDiameter,
oBalloon.Position.Y - dBalloonDiameter / 2))
Case 90
Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y +
Case 180
Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X - dBalloonDiameter,
Case 270
Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y -
dBalloonDiameter * 1.5))
End Select
'Add the GeometryIntent to the leader points collection.
'This is the geometry that the balloon will attach to.
Dim oGeometryIntent As Inventor.GeometryIntent
oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Call oLeaderPoints.Add(oGeometryIntent)
Dim oAttachBalloon As Inventor.Balloon
oAttachBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
'delete all leadernodes
Dim oLeaderNode As Inventor.LeaderNode
For Each oLeaderNode In oAttachBalloon.Leader.AllNodes
oLeaderNode.Delete()
Next
'TODO: Attach balloon to base balloon
Catch ex As Exception
End Try
End Sub
Solved by GVDB. Go to Solution.
I already found it!
replace:
By:
Dim oBalloonValueSets As Inventor.BalloonValueSets = oBalloon.BalloonValueSets
Dim oBalloonValueSet As Inventor.BalloonValueSet = oBalloonValueSets.Add(oComponentOccurrence)
This will attach balloon!
