I am trying to create Asymmetric Extrude Surface as follows:
Dim oExtrudeDef As ExtrudeDefinition
oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfileOne, PartFeatureOperationEnum.kSurfaceOperation)
oExtrudeDef.SetDistanceExtent(length + otherEndExtension, dir)
oExtrudeDef.SetDistanceExtentTwo(profileSideExtension) ' Create Surface Extrude Feature
Dim oExtrudeOne As ExtrudeFeature oExtrudeOne = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
But this does not work. Any idea?
Solved by Vladimir.Ananyev. Go to Solution.
The folowing code sample create asymmetric extruded surface:
10 mm in the positive direction + 40 mm in the negative direction.
Sub TestAsymmetricExtrusion() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition Dim oSketch As PlanarSketch Set oSketch = oDef.Sketches.Item(1) ' Create a profile based on the sketch geometry Dim oProfile As Profile Set oProfile = oSketch.Profiles.AddForSurface Dim oExtrudeDef As ExtrudeDefinition Set oExtrudeDef = oDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kSurfaceOperation) Call oExtrudeDef.SetDistanceExtent(1, kPositiveExtentDirection) Call oExtrudeDef.SetDistanceExtentTwo(4) Dim oExtrude As ExtrudeFeature Set oExtrude = oDef.Features.ExtrudeFeatures.Add(oExtrudeDef) End Sub
