Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Assign multiple parameters with the same value
4 REPLIES 4
cadmanagershat
554 Views, 4 Replies
Could anybody help me with this one please?
I am currently applying dimensions/constraints to our company logo with a view to creating an ifeature which we can insert at different scales across a range of products.
I am looking at creating a user parameter for scale (value of 1) which I can then assign to all other parameters as *scale. Problem is the total number of parameters concerned is scary so I am looking for a quick way to do this.
Any ideas?
4 REPLIES 4
salariua
in reply to: cadmanagershat
They are not so scarry if you export them and edit the xml with notepad or something similar where you can do a search replace.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
ekinsb
Here's a small VBA macro you can try.  It assumes the name of the parameter controlling the scale is "Scale".
Public Sub SetScaleOnParameters()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Dim partDef As PartComponentDefinition
    Set partDef = partDoc.ComponentDefinition
    Dim modelParam As ModelParameter
    For Each modelParam In partDef.Parameters.ModelParameters
        ' Check to see that this parameter defines a distance.
        If partDoc.UnitsOfMeasure.CompatibleUnits("1", modelParam.Units, "1", "in") Then
            ' Change the expression to include scale.
            modelParam.Expression = modelParam.Expression & " * Scale"
        End If
    Next
End Sub
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
cadmanagershat
in reply to: ekinsb
With a little tinkering that's done the trick.
Thank you very much
WHolzwarth
in reply to: ekinsb
Hmm. It's late, but I think, I've found an issue. Not all linear parameters are changed after applying Scale. See attached screenshots.
Parameters d16 and d39 are changed to (lh / 3 oE) - topthk * Scale, but should be (lh / 3 oE) * Scale - topthk * Scale. oE is German impression for ul = unitless.
Walter
Walter Holzwarth
