Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Assembly within assembly Detection
4 REPLIES 4
phillip.shields
494 Views, 4 Replies
I would like to see if there is a routine that allows my iLogic code to detect if my assembly contains another assembly within it. If my assebly contains assemblies then I don't want "MyRule" to run. Else if it does then I want "MyRule" to run.
4 REPLIES 4
Gruff
in reply to: phillip.shields
Write a function that returns a boolean.
in the function loop through the top level document's referencedDocuments property.
If any end in ".iam" stop looping and return a true.other wise return a false.
If you need to check part files as well then you will need to check each part files referencedDocuments Count property.  If it is > 0 then return true otherwise false.
jdkriek
Something like this:
Dim oDoc As Document = ThisDoc.Document
Dim oRefDoc As Document
Dim AsmFound As Boolean
For Each oRefDoc In oDoc.AllReferencedDocuments
	If oRefDoc.DocumentType = kAssemblyDocumentObject Then
		AsmFound = True
		Exit For
	End If
Next
If AsmFound = False Then
	iLogicVb.RunRule("MyRule")
End If
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Gruff
Actually Jonathon He only needs to check the references under the top level, not the all the referenced in his assembly.  That is why I suggested ReferencedDocument instead of AllReferencedDocuments.
Just as you are using an If..Exit in your loop when there is no point in continuing further.
phillip.shields
in reply to: jdkriek
Thanks that worked out great
