Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Assembly Constraint Entities
2 REPLIES 2
rjay75
466 Views, 2 Replies
On AssemblyConstraints what is the difference between EntityOne(Two) and GeometryOne(Two). When should one be used over the other?
Likewise with AffectedOccurrenceOne(Two) and OccurrenceOne(Two).
2 REPLIES 2
Vladimir.Ananyev
in reply to: rjay75
The EntityOne(Two) is an object which you can select in UI to add assembly constraint onto, while the GeometryOne(Two) is the geometry of the EntityOne(Two) which is representing the geometry information in assembly space. For example, if the EntityOne is a planar face, the corresponding GeometryOne is a Plane geometry object.
For the OccurrenceOne(Two) and AffectedOccurrenceOne(Two), you can create an assembly with below structure:
Now create an assembly constraint between Part1:1 and Part2:1, now check the OccurrenceOne and AffectedOccurrenceOne, they are both SubAssembly1:1. If you set the SubAssembly1:1 to be Adaptive, then check the OccurrenceOne and AffectedOccurrenceOne, they will be SubAssembly1:1 and Part1:1 respectively.
Hope this clears.  Thanks to Rocky Zhang  for this explanation.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
rjay75
in reply to: Vladimir.Ananyev
