Inventor Customization
Valued Mentor
SeanFarr
Message 1 of 6 (313 Views)
Assembly Colour Finish
313 Views, 5 Replies
01-15-2013 05:08 AM
I have borrowed a few lines of iLogic code to change all parts to the same colour from here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Color-multiple-parts-in-an-assembly/td-p/3191850#.UP...
Rule:
Dim num As Long
num = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Count
jj=1
While jj<num+1
Component.Color(ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Item(jj).Name) = paint_colour
jj=jj+1
End While
iLogicVb.UpdateWhenDone = True
This rule user a multi value text user parameter where I have input a group of colours.
I then apply this rule to my form for control of the final assembly.
Is there a way to alter this rule or better yet add another rule to over ride so that 3 parts of my assembly can be changed to another colour?
I have an assembly with ~200 parts and all same colour except for 3 parts. These three parts are the same colour as well. I can use specific files names in the rule as these will never change.
I would like to have a rule for this so I can add it to my form that I use to control size parameters and colours.
Sean
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
Hope the code below helps:
'name list of specific parts
' Note: case sensitive!!
Dim listOfSpecificPart() As String = New String(){"Part1:1", "part2:1"}
jj=1
While jj<num+1
Dim eachOccName
eachOccName = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Item(jj).Name
' check if this is a specific part
Dim oIndex As Integer = Array.IndexOf(listOfSpecificPart, eachOccName)
If oIndex > 0 Then
Component.Color(eachOccName) = black_colour
Else
Component.Color(eachOccName) = paint_colour
End If
jj=jj+1
End While
Valued Mentor
SeanFarr
Message 2 of 6 (311 Views)
Re: Assembly Colour Finish
01-15-2013 05:42 AM in reply to: SeanFarr
I meant to add some screenshots to help clarify. first image is what I currently have, Paint Finish changes all parts in the assembly to selected colour.
Second Image shows what I am trying to do, There are 3 parts called backplates that should be a different colour.
Any help would be awesome!!
Sean
Sean Farr
ADN Support Specialist
xiaodong.liang
Message 3 of 6 (278 Views)
01-22-2013 05:57 PM in reply to: SeanFarr
	jj=1
	While jj<num+1
	Dim eachOccName
	If  oIndex > 0 Then
	Else
	End If
	jj=jj+1
	End While
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Valued Mentor
SeanFarr
Message 4 of 6 (268 Views)
01-23-2013 08:14 AM in reply to: xiaodong.liang
This rule is almost perfect,
I have created another multi-value user parameter called backplate_colour, edited the rule you provided, added in the 3 parts file names and it works except for the first part file in the list of 3 doesn't change. It is not a problem with the part file, because I re-arranged the file order and it still doesnt apply the colour change to the first file in the list. Not sure what this could be.
I have attached a few images t show what I mean.
Sean Farr
Sean Farr
Valued Mentor
SeanFarr
Message 5 of 6 (263 Views)
01-24-2013 06:36 AM in reply to: xiaodong.liang
I still do know why the first part in the list of parts doesnt change colour, but I have found a work around.
I added the bolts to the list of parts and made sure it was first in the list, as these are painted with the frame (blue in this case). Bolts are MPC-100010
Then I added my 3 backplates (white in this case), so since the bolts were first in the list, they didn't change to white, but my 3 backplates changed. Backplates are MPC-100011, MPC-100012, MPC-100013
So it works, see attached image.
Thanks for your help.
Sean Farr
Sean Farr
Distinguished Contributor
sergelachance
Message 6 of 6 (117 Views)
10-25-2013 02:40 AM in reply to: SeanFarr
Hi :smileyhappy:
Do you think it's possible to create a same rule in drawing with a CommandeManager.Pick and select assembly view and send iproperties in all parts???
Thanks!
