In Apprentice when I loop through the component occurrences, as long as they are knormal, everything is fine. But if it is kPurchased then I get an unspecified error.
Is this a bug or what am I missing?
Hi Kent,
could you clarify if the issue is if you loop through an occurrence for its other properties, or if you access ComponentOccurrence.BOMStructure? Could you share a code demo?
At my side, with Apprentice, ComponentOccurrence.BOMStructure failed, no matter it is kNormal or other type.
