Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
API Place custom c/c part
1 REPLY 1
262 Views, 1 Reply
I'm looking for a way to place a custom content-center part in my assembly by rule.
Is this possible?
I found this code in the "programming help" but i cannot get it to work. And i guess it's for standard parts?
Sub PlaceContentCenterPart()
    ' Set a reference to the active assembly document.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the ContentCenter object.
    Dim oContentCenter As ContentCenter
    Set oContentCenter = ThisApplication.ContentCenter
    ' Get the content node (category) "Fasteners:Bolts:Hex Head"
    Dim oContentNode As ContentTreeViewNode
    Set oContentNode = oContentCenter.TreeViewTopNode.ChildNodes.Item("Fasteners").ChildNodes.Item("Bolts").ChildNodes.Item("Hex Head")
    ' Get the "ISO 4015" Family object.
    Dim oFamily As ContentFamily
    For Each oFamily In oContentNode.Families
        If oFamily.DisplayName = "ISO 4015" Then
            Exit For
        End If
    Next
    ' Create a member based on the first row of the family.
    Dim error As MemberManagerErrorsEnum
    Dim strContentPartFileName As String
    Dim strErrorMessage As String
    strContentPartFileName = oFamily.CreateMember(1, error, strErrorMessage)
    Dim oMat As Matrix
    Set oMat = ThisApplication.TransientGeometry.CreateMatrix
    ' Insert an instance of the content center member in the assembly.
    Call oDoc.ComponentDefinition.Occurrences.Add(strContentPartFileName, oMat)
End Sub
I'm getting these errors.
Rule Compile Errors in Plaats part, in Plaatsen van content center parts.iam
Error on Line 22 : Keyword is not valid as an identifier.
Error on Line 25 : Expression expected.
So I'm kinda stuck on this one. Getting this to work would save me loads of time in the future!
1 REPLY 1
Oké,
The first obvious error is out.. My bad.. adjusted the API sample a little and got it to work. Got a Standard Bolt (first size available) placed in my assembly.
How can i get the Bolt to be placed as a custom part?
        If oFamily.DisplayName = "DIN 931" Then
            Exit For
        End If
    Next
    Dim oError As MemberManagerErrorsEnum
    strContentPartFileName = oFamily.CreateMember(1, oError, strErrorMessage)
    Dim oMat As Matrix
