Analyze Interferance for entire assembly
4 REPLIES 4
747 Views, 4 Replies
I would like to click a button while in my assembly and have a macro cycle through and check interference between each of my parts. If it did not find an interference it would tell you when it was complete. Upon finding an interference, it would make a list of all of the part files that had interference detected. Anyone thought of this? Is this capability already out there?
Dan
4 REPLIES 4
Here's a VBA program that does it. It's fairly simple to do using the
AnalyzeInterference method.
Public Sub FindInterference()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oAsmDoc.ComponentDefinition
' Add each occurrence in the assembly to the object collection.
Dim oCheckSet As ObjectCollection
Set oCheckSet = ThisApplication.TransientObjects.CreateObjectCollection
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences
oCheckSet.Add oOcc
Next
' Call the AnalyzeInterference method, passing in a single
' collection. This will cause it to compare everything against
' everything else.
Dim oResults As InterferenceResults
Set oResults = oAsmCompDef.AnalyzeInterference(oCheckSet)
' Display the results of the interference.
Debug.Print "Interferences found: " & oResults.Count
Dim oResult As InterferenceResult
Dim iCount As Integer
iCount = 0
For Each oResult In oResults
iCount = iCount + 1
Debug.Print " Interference " & iCount
Debug.Print " Occurrence 1: " &
FullOccurrenceName(oResult.OccurrenceOne)
Debug.Print " Occurrence 2: " &
FullOccurrenceName(oResult.OccurrenceTwo)
Debug.Print " Volume: " & oResult.Volume & " cm^3"
Next
End Sub
' Used to display the full path of an occurrence. This is the path of the
' occurrence within the assembly structure.
Private Function FullOccurrenceName(Occ As ComponentOccurrence) As String
Dim i As Integer
For i = 1 To Occ.OccurrencePath.Count
If i = 1 Then
FullOccurrenceName = Occ.OccurrencePath.Item(i).Name
Else
FullOccurrenceName = FullOccurrenceName & "\" &
End If
Next
End Function
Brian Ekins
Autodesk Inventor API
wrote in message news:5123215@discussion.autodesk.com...
out there?
Dan
Dan,
I believe if you pre-select all the parts in the assembly (say in the browser) and then do Tools, Interference Analysis then you get a table of results as shown in the attached image.
Just making sure that it can be done through the UI. Thanks.
shekar
Hallo,
how did you make the interfering occurrences to display as red?
I use the following code to change the interfering occurences color, but i get the whole subassembly's also the part's color changed.
oCheckSet.Add oOcc
Next
' everything else.
iCount = 0
iCount = iCount + 1
Debug.Print " Occurrence 1: " & FullOccurrenceName(oResult.OccurrenceOne)
Debug.Print " Occurrence 2: " & FullOccurrenceName(oResult.OccurrenceTwo)
Dim oOccChange As ComponentOccurrence
Set oOccChange = oResult.OccurrenceTwo
MsgBox " Interference " & iCount & " ; Occurrence 1: " & FullOccurrenceName(oResult.OccurrenceOne) & "Occurrence 2: " & FullOccurrenceName(oResult.OccurrenceTwo) & " Volume: " & oResult.Volume & " cm^3"
'MsgBox " Occurrence 1: " & FullOccurrenceName(oResult.OccurrenceOne)
'MsgBox " Occurrence 2: " & FullOccurrenceName(oResult.OccurrenceTwo)
'MsgBox " Volume: " & oResult.Volume & " cm^3"
'MsgBox "Type" & oResult.Type
Call oOccChange.SetRenderStyle(kOverrideRenderStyle, oAsmDoc.RenderStyles.Item(14))
Next
End Sub
Dim i As Integer
If i = 1 Then
Else
FullOccurrenceName = FullOccurrenceName & "\" & Occ.OccurrencePath.Item(i).Name
End If
Next
End Function
how can I only change the interfering part's color?
thank you so much!! Edited by: jennypet on Nov 17, 2009 9:15 AM
Hallo Brian,
i have a question to the interference results.
what should I do if I want to display the interference volume as red?
cause though the code above can I still not able to see the interference direktly.
thanks so much if you can provide me a advise!
Lin
