Inventor Customization
Valued Contributor
wowens63
Message 1 of 6 (232 Views)
adding to existing KnitFeature
232 Views, 5 Replies
07-29-2013 08:49 AM
how would i go about adding a new surface to existing knitFeature with the API
It is possible to add surfaces to an existing knit feature.  Below is some sample code I used to verify it and the part (Inventor 2014) I used to test it.
An important thing to understand is that the surface you're adding to the stitch must exist in the browser tree before the stitch feature.  You can why this is a requirement when you try to do the same thing through the user-interface.  When you edit any feature, it rolls the tree back to the state where that feature was created, which means you don't have access to anything created after it.
Public Sub AddToKnit()
Dim partDoc As PartDocument
Set partDoc = ThisApplication.ActiveDocument
Dim existingKnit As KnitFeature
Do
Dim selectedFeature As PartFeature
Set selectedFeature = ThisApplication.CommandManager.Pick( _
kPartFeatureFilter, "Select a stitch feature.")
If selectedFeature Is Nothing Then
Exit Sub
End If
If TypeOf selectedFeature Is KnitFeature Then
Set existingKnit = selectedFeature
Else
MsgBox "The selected feature must be a stitch feature."
End If
Loop While existingKnit Is Nothing
Dim surfaceFeature As WorkSurface
Set surfaceFeature = ThisApplication.CommandManager.Pick( _
kPartBodyFilter, "Select a body to add to the stitch feature.")
Dim newBody As Object
Set newBody = surfaceFeature.SurfaceBodies.Item(1)
Dim bodies As ObjectCollection
Set bodies = existingKnit.Surfaces
Call bodies.Add(surfaceFeature)
existingKnit.Surfaces = bodies
End Sub
ADN Support Specialist
wayne.brill
Message 2 of 6 (205 Views)
Re: adding to existing KnitFeature
07-30-2013 01:02 PM in reply to: wowens63
I am not sure I understand your question. The API allows you to create a KnitFeature using the Add method of the KnitFeatures collection. This Add method takes an ObjectCollection of surfaces. The help file has a VBA example:
StitchFeatureCreate()
You could get the worksurfaces from the existing KnitFeature you want to knit together and put them in the ObjectCollection that you pass to KnitFeatures.Add().
Here is some VBA code I used to test:
Sub addToStitchFeature()
        Dim oPartDoc As PartDocument
        Set oPartDoc = ThisApplication.ActiveDocument
         Dim oCompDef As PartComponentDefinition
         Set oCompDef = oPartDoc.ComponentDefinition
        Dim oSrf1 As WorkSurface
        Set oSrf1 = oPartDoc.SelectSet(1)
        Dim oSrf2 As WorkSurface
        Set oSrf2 = oPartDoc.SelectSet(2)
         Dim oSurfaces As ObjectCollection
         Set oSurfaces = ThisApplication.TransientObjects.CreateObjectCollection
        oSurfaces.Add oSrf1
        oSurfaces.Add oSrf2
       Dim oKnitFeature As KnitFeature
       Set oKnitFeature = oCompDef.Features.KnitFeatures.Add(oSurfaces)
   End Sub
The attached screenshots help explain.
Hope this helps,
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Valued Contributor
wowens63
Message 3 of 6 (195 Views)
07-30-2013 02:35 PM in reply to: wayne.brill
yes you are correct, and i do have the same code. the problem is after making the
I cant keep adding more surfaces to it. the only way i found that works is to delete the "oKnitFeature"
and remake it will all the surfaces.
wayne.brill
Message 4 of 6 (169 Views)
08-05-2013 02:14 PM in reply to: wowens63
I have not found any way to add a new surface to a KnitFeature and agree with you that the faces needed to be added to the KnitFeature when it is created with the Add method. If you would like this functionality added to the API please log a post on the Inventor Idea Station.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Wayne
Wayne Brill
ekinsb
Message 5 of 6 (132 Views)
08-16-2013 01:19 PM in reply to: wowens63
    Do
            Exit Sub
        End If
        Else
        End If
End Sub
Brian Ekins
Valued Contributor
wowens63
Message 6 of 6 (128 Views)
08-16-2013 02:21 PM in reply to: wowens63
Thank you
