Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Adding an Icon to the assembly panel
16 REPLIES 16
Message 1 of 17
278 Views, 16 Replies
Ok, I have tried this several diffent ways and to no avail. How do I get the "Assembly Panel" to accept a new Icon? The examples show you how to add an new panel, but I would like to add a new one to the existing panel. TIA, Mike
16 REPLIES 16
Message 2 of 17
I could be wrong but given that the API exposes no
method for accessing existing commandbar objects, it does not appear that you
can add a button to the Assembly panel.
There are 10 kinds of people. Those who understand binary and
those who don't.
http://code.acadx.com
(Pull the pin
to reply)
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Ok,
Mike
Message 3 of 17
There has to be, Kent adds his to the "Part Features" panel the code must be very similar, I'm just missing something. Mike
Message 4 of 17
The code for the Addin creation sample in helps adds a toolbutton to the Panelbar sketch
environment. Does that help any?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"MDB" wrote in message news:f196d1f.-1@WebX.maYIadrTaRb...
Message 5 of 17
I'd just like to if possible drop it on the "Assembly Panel"
Thanks, Mike
Message 6 of 17
Mike
Is this a Addin?
Here is from the program I just did which adds a icon to the assembly browser bar.
' Save a reference to the Application object.
Set oApp = AddInSiteObject.Application
Dim oIcon1 As IPictureDisp
Set oIcon1 = LoadResPicture(101, vbResBitmap)
'****** Switch out the next calls / use first for debug and second for release
If InDebug Then
Set oButtonHandler1 =
AddInSiteObject.CreateButtonDefinitionHandler("KWiKDriveCmd1", _
kFileOperationsCmdType, "KWiKDrive", "Constraint Min Max Drive", "Drive")
Else
On Error Resume Next
kFileOperationsCmdType, "KWiKDrive", "Constraint Min Max Drive", "Drive",
oIcon1)
If Err.Number = -2147418113 Then
Set oButtonHandler1 = Nothing
Err.Clear
On Error GoTo 0
End If
End If
' Set a reference to the environment base collection.
Dim oEnvBaseColl As EnvironmentBaseCollection
Set oEnvBaseColl = oApp.EnvironmentBaseCollection
' Create a new command bar
Dim oCommandBar As CommandBarBase
Set oCommandBar = oEnvBaseColl.CommandBarBaseCollection.Add("KWiKDrive")
' Add a control to the command bar.
Call oCommandBar.Controls.Add(kBarControlButton, _
oButtonHandler1.ControlDefinition)
Dim oAsmCommandBar As CommandBarBase
Set oAsmCommandBar = oEnvBaseColl.CommandBarBaseCollection.Item( _
"AMxAssemblyPanelCmdBar")
Call oAsmCommandBar.Controls.Add(kBarControlButton, _
Kent
Assistant Moderator
"MDB" wrote in message news:f196d1f.3@WebX.maYIadrTaRb...
> Thanks, Mike
Message 7 of 17
Kent Keller wrote:
> oEnvBaseColl.CommandBarBaseCollection.Add("KWiKDrive") ' Add a
> control to the command bar. Call
MDB,
Note the call to the Add method. This gives you a new ComandBar within a
given environment. It does not allow you to add a button to an existing
CommandBar. This is what I was referring to.
There are 10 kinds of people. Those who understand binary and those who
don't.
(Pull the pin to reply)
Message 8 of 17
Kent, the addin section adds another command bar to the Assembly Panel, I guess, as Frank pointed out it is not available (yet) to allow additional controls to the Assembly toolbar itself.
br>Unless Brian has a way of doing it I have not figured it out yet.
Frank and Kent
Mike
Message 9 of 17
I guess I am not following. In my mind the Assembly Panel is a toolbar..... i.e. go to
customize, Toolbars, select Assembly Panel and "Show"
What other Assembly bar are you talking about?
Kent
Assistant Moderator
"MDB" wrote in message news:f196d1f.6@WebX.maYIadrTaRb...
toolbar itself.
> Frank and Kent
> Thanks,
> Mike
Message 10 of 17
> toolbar..... i.e. go to customize, Toolbars, select Assembly Panel
> and "Show"
While you can add your own panels to a given environment, MDB is wanting
to add a buton to an existing panel (i.e. "Assembly Panel", "Tube &
Pipe"). I do not think this is possible but would love to be proven
wrong.
don't.
Message 11 of 17
Here is an example of adding toolbuttons a new toolbar and the assembly
panel bar. The following code is in the ApplicationAddInServer_Activate
procedure. (watch for word wrap)
- Note that the images in this code are loaded from a resourse file.
- A public constant has been declared: kErrorDebugMode = -2147418113
- The error handler enables text display in place of the icons when
debugging the add-in.
Dim oIcon2 As IPictureDisp
Set oIcon1 = LoadResPicture(102, vbResIcon)
Set oIcon2 = LoadResPicture(103, vbResIcon)
'get a reference to the IV application object
Set m_oIVApp = AddInSiteObject.Application
AddInSiteObject.CreateButtonDefinitionHandler("AnimatorV4Cmd1", _
kFileOperationsCmdType, "Animate", "Animator 4", "Animate", oIcon1,
oIcon2)
If Err.Number = kErrorDebugMode Then
kFileOperationsCmdType, "Animate", "Animator 4", "Animate")
Err.Clear
On Error GoTo 0
End If
'set a reference to the environment base collection
Set oEnvBaseColl = m_oIVApp.EnvironmentBaseCollection
'create a new command bar
Set oCommandBar = oEnvBaseColl.CommandBarBaseCollection.Add("Animator")
'add a button to the new command bar
'get a reference to the assembly panel bar
oEnvBaseColl.CommandBarBaseCollection.Item("AMxAssemblyPanelCmdBar")
'add a button to the Assembly panel bar
Hope this helps some,
Neil
"Frank Oquendo" wrote in message
news:EE6433BABDE26E9CDDD161DABBB69C8F@in.WebX.maYIadrTaRb...
> > and "Show"
> wrong.
> don't.
Message 12 of 17
That is what the Code that I posted and Neil posted now does.
Here is my assembly panel bar, the last 5 icons on the right were added
by Addins using the same basic code as what I posted.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
> > and "Show"
wanting
> wrong.
who
> don't.
Message 13 of 17
Now *that's* cool!
don't.
Message 14 of 17
Apologies Kent, I skipped over the earlier posts and didn't see your code.
Neil
"Kent Keller" wrote in message
news:CB32E658288A3B4F085E9A2D1C94DFE3@in.WebX.maYIadrTaRb...
> Kent Keller
> Assistant Moderator
> > > and "Show"
> wanting
> > wrong.
> who
> > don't.
Message 15 of 17
No problem, I probably originally stole it from either you or Charles. 8^)
Maybe we will just remove 1 from my tab that I owe you. 8^))
Kent
Assistant Moderator
"Neil Munro" wrote in message
news:EF120EB09A1D0A00C2992B796EFDC99F@in.WebX.maYIadrTaRb...
> Neil
Message 16 of 17
I have just replied to Frank's Environmentr IDs post on the 23/10/03
complete with a list of all the command bars in the command bar base
collection... if anyone needs it, I'll dig out the code for iterating over
the command bar base collection if anyone needs it.
Scott
Message 17 of 17
I would be interested but even more so in how to build a flyout or
popup. I have a series of commands I would like to have work similar
to the workpoint command bar or the 2D Constraints command bar where
there is one icon, you pick it and a series of others pops up.
Scott Stubbington wrote:
>Hello,
>Scott
