I'm trying to create a registry-free addin here using Inventor 2013 and VB Express 2013. I've been using the AddIn template for VB.NET and http://modthemachine.typepad.com/files/VBAtoAddIn.pdf to create the addin, but the button I created (and the addin I assume), won't appear in Inventor.
-Both the addin file and dll are in %APPDATA%\Autodesk\Inventor 2013\, and VB Express is pointed to build there.
-I've tried .Net 3.5, 4, and 4.5
-Inventor 2013 Build 138, 03/01/12
The .addin code:
<Addin Type="Standard"> <!--Created for Autodesk Inventor Version 17.0--> <ClassId>{63e02af8-a71d-4c70-8319-75da45602d4f}</ClassId> <ClientId>{63e02af8-a71d-4c70-8319-75da45602d4f}</ClientId> <DisplayName>PCB_Importer_AddIn</DisplayName> <Description>PCB_Importer_AddIn</Description> <Assembly>%APPDATA%\Autodesk\Inventor 2013\Addins\PCB_Importer_AddIn.dll</Assembly> <!--<LoadOnStartUp>1</LoadOnStartUp>--> <UserUnloadable>1</UserUnloadable> <Hidden>0</Hidden> <SupportedSoftwareVersionGreaterThan>16..</SupportedSoftwareVersionGreaterThan> <DataVersion>1</DataVersion> <UserInterfaceVersion>9</UserInterfaceVersion> <LoadBehavior>2</LoadBehavior> <LoadAutomatically>1</LoadAutomatically> </Addin>
The Activate sub and ribbon creation sub:
Private m_inventorApplication As Inventor.Application Private m_ClientID As String Private WithEvents m_buttonDef As ButtonDefinition Private WithEvents userInterfaceEvents As UserInterfaceEvents #Region "ApplicationAddInServer Members" Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate ' This method is called by Inventor when it loads the AddIn. ' The AddInSiteObject provides access to the Inventor Application object. ' The FirstTime flag indicates if the AddIn is loaded for the first time. ' Initialize AddIn members. m_inventorApplication = addInSiteObject.Application m_ClientID = AddInGuid(GetType(StandardAddInServer)) ' TODO: Add ApplicationAddInServer.Activate implementation. ' e.g. event initialization, command creation etc. ' Get a reference to the UserInterfaceManager object. Dim UIManager As Inventor.UserInterfaceManager = m_inventorApplication.UserInterfaceManager ' Get the control definitions collection. Dim controlDefs As ControlDefinitions = m_inventorApplication.CommandManager.ControlDefinitions 'Dim smallPicture As IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.icon16) 'Set the large icon size based on wheter it is the classic or ribbon interface 'Dim largePicture As IPictureDisp 'If UIManager.InterfaceStyle = InterfaceStyleEnum.kRibbonInterface Then ' largePicture = PictureDispConverter.ToIPictureDisp(My.Resources.icon32) 'Else ' largePicture = PictureDispConverter.ToIPictureDisp(My.Resources.icon24) 'End If 'Set the addin button definition Try m_buttonDef = controlDefs.Item("AltiumImportButton") Catch ex As Exception m_buttonDef = controlDefs.AddButtonDefinition(DisplayName:="Altium Importer", InternalName:="AltiumImportButton", Classification:=CommandTypesEnum.kEditMaskCmdType, _ ClientId:=m_ClientID) End Try If (firstTime) Then If UIManager.InterfaceStyle = InterfaceStyleEnum.kRibbonInterface Then CreateOrUpdateRibbonUserInterface() ElseIf UIManager.InterfaceStyle = InterfaceStyleEnum.kClassicInterface Then CreateClassicInterface() End If End If End Sub ' This property uses reflection to get the value for the GuidAttribute attached to the class. Public Shared ReadOnly Property AddInGuid(ByVal t As Type) As String Get Dim guid As String = "" Try Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False) Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute) guid = "{" + guidAttribute.Value.ToString() + "}" Finally AddInGuid = guid End Try End Get End Property 'Create User Interface Private Sub CreateOrUpdateRibbonUserInterface() 'Get a reference to the UserInterfaceManager object. Dim UIManager As Inventor.UserInterfaceManager = m_inventorApplication.UserInterfaceManager 'Get the assembly ribbon Dim assemblyRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("Assembly") 'Get the "Assemble" tab Dim assembleTab As Inventor.RibbonTab assembleTab = assemblyRibbon.RibbonTabs.Item("id_TabAssemble") 'Create a new panel on the Assembly tab Dim panel As Inventor.RibbonPanel panel = assembleTab.RibbonPanels.Add(DisplayName:="PCB Importer", InternalName:="AssembleTabPCBImporterPanel", ClientId:=m_ClientID) 'Add the button to the tab panel.CommandControls.AddButton(m_buttonDef, True) End Sub #End Region
Try to put a break point at the beginning of the Activate method.
If it does not get enabled when Inventor starts then maybe the wrong dll is loaded or it has some unresolved dependency.
If it does get enabled then you can step through the code and see if all goes fine.
In theory even in VB Express you can do debugging by editing the project file in a text editor and adding some entries.
Cheers,
