Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
add user path to projet file does not work (userpath is striked through)
2 REPLIES 2
551 Views, 2 Replies
 Sub Project()
        ' Set a reference to the DesignProjectManager object.
        Dim oDesignProjectMgr As DesignProjectManager
        Set oDesignProjectMgr = ThisApplication.DesignProjectManager
        Dim oProject As DesignProject
        Dim oDesignProject As DesignProject
        Set oDesignProject = oDesignProjectMgr.ActiveDesignProject
        Dim oFrequenlyUsedPaths As ProjectPaths
        Set oFrequenlyUsedPaths = oDesignProject.FrequentlyUsedPaths
        Dim oProjectName As String
        oProjectName = "Project1"
        Dim oProjectLocation As String
        oProjectLocation = "C:\temp" 'assumes there's a folder called c:\temp
        Set oProject = oDesignProjectMgr.DesignProjects.Add(MultiUserModeEnum.kSingleUserMode, oProjectName, oProjectLocation)
        Dim oFus As ProjectPaths
        Call oProject.FrequentlyUsedPaths.Add("FreqUsedSubFolder", "C:\temp\test") 'assumes there's a folder called c:\temp\test
        oProject.Activate
  End Sub
 This is the code from the samples in inventor help, i would like to add a frequently used subfolder.
But the path is striked through. When i manually do this in the project by choosing a folder, inventor accepts the path?
Is this a bug or not possible?
2 REPLIES 2
Please anyone? This should be working
Solved myself
