Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
add rule to an external rule prblems
5 REPLIES 5
Ray_P
515 Views, 5 Replies
How do I add an external rule to an external rule. Or I have an external  rule that exists and when I add to it I get errors. Both of these rules run fine alone. I want to add 2 lines of code to the end of an existing rule that all parts are already triggered to run at save.
see attached.
5 REPLIES 5
Radioflyer651
in reply to: Ray_P
Hi Ray,
My guess is that, because you're using a "Sub Main", and an additional function, your additional lines of code must be in the "Sub Main" to execute.
When you're using functions and subs, all executable code must be in a sub or function.
Richard
Ray_P
in reply to: Radioflyer651
Thanks I tried it below the sub & got errors- never thought of adding to above sub.
 I serously need a course in the ILOGIC code!
Ray_P
Thanks Rich: I was wondering if you could help me with this string.
iProperties.Value("Project", "Designer")= Environment.UserName
this works alone but when I add it to the sub main I get the error "user name is not a member of inventor environment."
 I am tring to capture the windows user name and slip it to the designer and author field on save. The Inventor (options) user name can be modified to easily.
Thanks for your time.
Radioflyer651
in reply to: Ray_P
Oddly, mine worked when I added it to the Sub Main.  There might be some other things going on, but try using:
iProperties.Value("Project", "Designer")= System.Environment.UserName
Richard
Ray_P
in reply to: Ray_P
Thanks Richard -
System.environment.user name worked great!
