Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
add part border dont work....
2 REPLIES 2
315 Views, 2 Replies
' create a drawing
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawingDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oView1 as DrawingView
ViewScale = 1/1
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
    oPartDoc = ThisDoc.Document
    'Define IDW Template File Location
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "d:\Work12\TEMPLATES\PPPI-PART BORDER NL.idw", True)
    'oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "", True)
    oSheet = oDrawingDoc.Sheets.Item(1)
    ' Create a new NameValueMap object
 	 Dim oBaseViewOptions As NameValueMap
  	oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
  	oBaseViewOptions.Add("SheetMetalFoldedModel", False)
	'Define 2d view bottom left corner points for four views
	oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(10, 12) ' front view
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kShadedHiddenLineDrawingViewStyle, "My View")
	oSheet.PartsLists.Add(oView1, ThisApplication.TransientGeometry.CreatePoint2d(27,20.625))
Please take a look at the code below, can someone tell me what am I doing wrong?
???oSheet.PartsLists.Add(oView1, ThisApplication.TransientGeometry.CreatePoint2d(27,20.625))
Thank you
2 REPLIES 2
Vladimir.Ananyev
In your command  oSheet.PartsLists.Add(oView1, ... )
oView1 object is undefined.
Replace it with the reference to the existing drawing view, e.g.  oBaseView.
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
in reply to: Vladimir.Ananyev
thank you! spasibo!
