Somebody please explain to me how this works below ... I want the revision cloud tool, intalled the .msi, and nothing???
"Comments2
JmetalFri Mar 22, 2013 10:42 am
Am I correct in my understanding that there is not an easy way to create revision clouds?
paul.normandFri Mar 22, 2013 11:52 am
Hi Jmetal,
You are correct that it is not part of the default install. However, we do provide an optional install that does create a revision cloud. Go to C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK and install the UserTools.msi. After installation, click the AddIns tab when you are in a drawing and the Revision Cloud command is available in the Drawing Tools panel.
Cheers,
Paul (autodesk)"
Solved by jdkriek. Go to Solution.
Hey,
I got it to work. Apparently I needed administrative access to complete the install.
Thanks for the reply.
