Im looking at the ifeature example in the help but i need to create an iFeature on the XY plane instead of a face.
From example:
Dim oFace As Face: Set oFace = oPartDoc.SelectSet.Item(1)
Looking through the forum in think i need to reference the work plane as a planar entity but im struggling with the wording.
The direction i was heading was:
Dim oPlane As WorkPlane: Set oPlane = oPartDoc.ComponentDefinition.WorkPlanes.Item("XY Plane")
Then further down in the code
Dim oPlaneInput As iFeatureSketchPlaneInput
Set oPlaneInput = oInput
oPlaneInput.PlaneInput = oPlane 'Previoulsy was oFace
Solved by Curtis_Waguespack. Go to Solution.
Hi CadUser46,
Here is a quick example that should work for you (just change the path to the iFeature").
I hope this helps.
Curtis
' Set a reference to part file Dim oDoc As PartDocument oDoc = ThisApplication.ActiveDocument ' Set a reference to the part component definition. Dim oCompDef As PartComponentDefinition oCompDef = oDoc.ComponentDefinition 'get the XY work plane. Dim xyPlane As Inventor.WorkPlane xyPlane = oCompDef.WorkPlanes.Item(3) 'select the work plane oDoc.SelectSet.Select(xyPlane) 'look at the work plane
Dim oControlDef As ControlDefinition
oControlDef = ThisApplication.CommandManager. _
ControlDefinitions.Item("AppLookAtCmd")
oControlDef.Execute 'reference the part features collection Dim oFeatures As PartFeatures oFeatures = oCompDef.Features 'create an iFeatureDefinition object. Dim oiFeatureDef As iFeatureDefinition oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition( _ "C:\Temp\End_mill_curved.ide") ' Set the input. Dim oInput As iFeatureInput For Each oInput In oiFeatureDef.iFeatureInputs Dim oParamInput As iFeatureParameterInput Select Case oInput.Name Case "Sketch Plane" Dim oPlaneInput As iFeatureSketchPlaneInput oPlaneInput = oInput oPlaneInput.PlaneInput = xyPlane Case "Diameter" oParamInput = oInput oParamInput.Expression = "1 in" Case "Depth" oParamInput = oInput oParamInput.Expression = "0.5 in" End Select Next ' Create the iFeature. Dim oiFeature As iFeature oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
Curtis. Thanks for the quick reply but its not working for me. Once i convert the .net to vba
i get the 'Object doesnt support this property or method' error when it gets to the odoc.select set line. What am i missing?
Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition Set oCompDef = oDoc.ComponentDefinition
Set xyPlane = oCompDef.WorkPlanes.Item("XY Plane")
oDoc.SelectSet.Select (xyPlane)
Meanwhile i had updated my original code as below but doing it this way i get a type mismatch error at the same point
Public Sub PlaceMyiFeature()
'Get the part document.
Dim oPartDoc As PartDocument: Set oPartDoc = ThisApplication.ActiveDocument
'Get the XY Front plane
'Select the work plane
Dim mySelect As SelectSet
Set mySelect = oPartDoc.SelectSet.Select(oPlane)
'Reference the part features collection
Dim oFeatures As PartFeatures: Set oFeatures = oPartDoc.ComponentDefinition.Features
'Create an iFeatureDefinition object.
Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\Temp\iFeatureTEST.ide")
'Set the input.
Case "Sketch Plane"
End Select
Next
Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef) End Sub
PS: How do you get your source code to display like that in the forum post? I tried just searching the FAQs and boards before replying but cant see anything.
Hi CadUser46,
I had a quick look at this, and I think all I changed was where you had this:
I changed it to this:
Call oPartDoc.SelectSet.Select(oPlane)
But it occurred to me you don't actually need the lines selecting the plane at all. I had it in my iLogic rule, as I was re-using some other code that was intended to change the view and "look at" the feature once created.
As for placing the code in the code window, you can use the little C button as shown to open a window into which to paste your code:
Below, is your full code that I had working from the VBA editor.
I hope this helps.
Curtis
Public Sub PlaceMyiFeature() 'Get the part document. Dim oPartDoc As PartDocument: Set oPartDoc = ThisApplication.ActiveDocument 'Get the XY Front plane Dim oPlane As WorkPlane: Set oPlane = oPartDoc.ComponentDefinition.WorkPlanes.Item("XY Plane") 'Reference the part features collection Dim oFeatures As PartFeatures: Set oFeatures = oPartDoc.ComponentDefinition.Features 'Create an iFeatureDefinition object. Dim oiFeatureDef As iFeatureDefinition Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\Temp\iFeatureTEST.ide") 'Set the input. Dim oInput As iFeatureInput For Each oInput In oiFeatureDef.iFeatureInputs Dim oParamInput As iFeatureParameterInput Select Case oInput.Name Case "Sketch Plane" Dim oPlaneInput As iFeatureSketchPlaneInput Set oPlaneInput = oInput oPlaneInput.PlaneInput = oPlane End Select Next ' Create the iFeature. Dim oiFeature As iFeature Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef) End Sub
Curtis. Its now resorted back to an error i had earlier but didnt persue until i got this fixed. It fails at the 'Set oiFeature' line where im referencing my iFeatureTest.ide.
I tested one of the default ifeatures using a UNC path and the code works fine so im inclined to think its something about my ifeature. Can you take a look and see im not missing something obvious. I have attached the ifeature.
Some background on this. Im trying to create geometry from nothing using a series of ifeatures as opposed to cutting something out of existing model geometry. So from a blank file, run the macro, insert ifeatureTest.ide.
Also how do you know when to use call versus not using it?
Curtis, i figured it out. in the ifeature the sketch plane inherited the default name 'Sketch Plane1'. In the select case statement it was looking for 'Sketch Plane'.
I think i can begin to make some progress from here. Thanks.
PS: Keep up the blog. I think i have read it front to back 10 times over.
anybody have a ifeatures and part with ilogic code in for exemple???
Thanks for your help!
