Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Add flange to part in assembly
2 REPLIES 2
askokk
436 Views, 2 Replies
Hello.
Im just getting started with API and would like you to show me some guidelines.
For my first project Im trying to following:
Assembly document is open. In this assembly there is a sheet metal part called "BAR"
Now what i want to do is select one of sheet metal part edges using pick function and add a flange to that edge.
Something like this was able to do that in in part environment:
Public Sub addflange()
Dim oSheetMetalDoc As PartDocument
Set oSheetMetalDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
Set oCompDef = oSheetMetalDoc.ComponentDefinition
Dim oSheetMetalFeatures  As SheetMetalFeatures
Set oSheetMetalFeatures = oCompDef.Features
'Pick edge
Dim oEdge As Object
Set oEdge = ThisApplication.CommandManager.Pick(kPartEdgeFilter, "edge")
'Add edge to edges collection
Dim oEdgeC As EdgeCollection
Set oEdgeC = ThisApplication.TransientObjects.CreateEdgeCollection
Call oEdgeC.Add(oEdge)
'Create flange definiton
Dim oFlangeDef As FlangeDefinition
Set oFlangeDef = oSheetMetalFeatures.FlangeFeatures.CreateFlangeDefinition(oEdgeC, "45 deg", 20)
'Add flange
Dim oFlangeFeature As FlangeFeature
Set oFlangeFeature = oSheetMetalFeatures.FlangeFeatures.Add(oFlangeDef)
End Sub
But I need it to be done in ASSEMBLY environment.
So that the active document  would be assembly document, select PART edge from ASSEMBLY document  (i think this is where i get lost) and then add flange to this sheet metal part file.
Am I on heading to the right direction?
Any suggestions?
2 REPLIES 2
askokk
in reply to: askokk
Been looking around a little.. are "Face Proxies" something I have to create here?
askokk
in reply to: askokk
Got it working.
It turns out that "Edge proxies" are allready there.. no need to create one:D
I just had to use EdgeProxy.NativeObject instead of just Edge.
