Hello.
Im just getting started with API and would like you to show me some guidelines.
For my first project Im trying to following:
Assembly document is open. In this assembly there is a sheet metal part called "BAR"
Now what i want to do is select one of sheet metal part edges using pick function and add a flange to that edge.
Something like this was able to do that in in part environment:
Public Sub addflange() Dim oSheetMetalDoc As PartDocument Set oSheetMetalDoc = ThisApplication.ActiveDocument Dim oCompDef As SheetMetalComponentDefinition Set oCompDef = oSheetMetalDoc.ComponentDefinition Dim oSheetMetalFeatures As SheetMetalFeatures Set oSheetMetalFeatures = oCompDef.Features 'Pick edge Dim oEdge As Object Set oEdge = ThisApplication.CommandManager.Pick(kPartEdgeFilter, "edge") 'Add edge to edges collection Dim oEdgeC As EdgeCollection Set oEdgeC = ThisApplication.TransientObjects.CreateEdgeCollection Call oEdgeC.Add(oEdge) 'Create flange definiton Dim oFlangeDef As FlangeDefinition Set oFlangeDef = oSheetMetalFeatures.FlangeFeatures.CreateFlangeDefinition(oEdgeC, "45 deg", 20) 'Add flange Dim oFlangeFeature As FlangeFeature Set oFlangeFeature = oSheetMetalFeatures.FlangeFeatures.Add(oFlangeDef) End Sub
But I need it to be done in ASSEMBLY environment.
So that the active document would be assembly document, select PART edge from ASSEMBLY document (i think this is where i get lost) and then add flange to this sheet metal part file.
Am I on heading to the right direction?
Any suggestions?
Got it working.
It turns out that "Edge proxies" are allready there.. no need to create one:D
I just had to use EdgeProxy.NativeObject instead of just Edge.
