It's possible to add baseview on specific layer?
anybody have a code for that?
Thanks for you help 🙂
You can't directly take drawing views to layer.But you can select all drawing curves & you can assign to any layer.I hope this link will guide you in right direction
Here i modified for base view :
Dim oDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet = oDoc.ActiveSheet Dim oView As DrawingView For Each oView In oSheet.DrawingViews ' If it is a Baseview If oView.ViewType = KstandardDrawingViewType Then ' Get Layers Dim oLayers As LayersEnumerator = oView.Parent.Parent.StylesManager.layers ' Get CNC layer Dim oLayer As Layer = oLayers.Item("0.1mm") ' Get lines Dim oCurves As DrawingCurvesEnumerator = oView.DrawingCurves() Dim oCurve As DrawingCurve ' For each line For Each oCurve In oCurves ' Change the layer oCurve.Segments.Item(1).Layer = oLayer Next End If Next
Thanks for your help prokasht66 🙂
I know this code to change the layer view, what's i want it's to insert a baseview directly on a good layer!
Maybe someone have my solution 🙂
As Prakasht66 mentioned, you can't do that. Take a look at the "DrawingViews.AddBaseView" method in the help and you will see that their is no option to set the layer before inserting the view.
You can however move all curves at once using the optimized API "Sheet.ChangeLayer":
' This sample demonstrates the performance difference of changing the layer ' of individual objects one at a time, or a group of objects at the same time. ' Make sure the g_FilePath variable points to where the Carb.ipt file is located. ' Other than that there are no requirements for running this sample since it ' creates its own drawing. Public Sub DrawingChangeLayer() ' Create a new drawing Dim drawDoc As DrawingDocument Set drawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject) Dim Tg As TransientGeometry Set Tg = ThisApplication.TransientGeometry ' Add drawing views of the same part and same orientation. Dim modelDoc As PartDocument Set modelDoc = ThisApplication.Documents.Open(g_FilePath & "Carb.ipt", False) Dim drawView1 As DrawingView Dim drawView2 As DrawingView Set drawView1 = drawDoc.activeSheet.DrawingViews.AddBaseView(modelDoc, Tg.CreatePoint2d(8, 8), 3, kFrontViewOrientation, kHiddenLineDrawingViewStyle) Set drawView2 = drawDoc.activeSheet.DrawingViews.AddBaseView(modelDoc, Tg.CreatePoint2d(20, 8), 3, kFrontViewOrientation, kHiddenLineDrawingViewStyle) ' Create a new layer to move the geometry to. Dim newLayer As Layer Set newLayer = drawDoc.StylesManager.Layers.item(1).Copy("My New Layer 1") newLayer.color = ThisApplication.TransientObjects.CreateColor(255, 0, 0) newLayer.LineType = kContinuousLineType Dim timer As New clsTimer ' Iterate over all of the curves in the first view and change their layer one at a time. timer.start Dim drawCurve As DrawingCurve For Each drawCurve In drawView1.DrawingCurves Dim curveSegment As DrawingCurveSegment For Each curveSegment In drawCurve.Segments curveSegment.Layer = newLayer Next Next Dim time1 As Double time1 = timer.CurrentTime Set newLayer = drawDoc.StylesManager.Layers.item(1).Copy("My New Layer 2") newLayer.color = ThisApplication.TransientObjects.CreateColor(0, 255, 0) newLayer.LineType = kContinuousLineType ' Change the layer for all curves at one time. timer.start Dim curves As ObjectCollection Set curves = ThisApplication.TransientObjects.CreateObjectCollection For Each drawCurve In drawView2.DrawingCurves For Each curveSegment In drawCurve.Segments Call curves.Add(curveSegment) Next Next Call drawDoc.activeSheet.ChangeLayer(curves, newLayer) Dim time2 As Double time2 = timer.CurrentTime Dim x As Double x = time1 / time2 MsgBox "Change layer results for " & curves.count & " entities." & vbCr & "One at a time: " & VBA.Format(time1, "0.00000") & vbCr & "All at once: " & VBA.Format(time2, "0.00000") & vbCr & "Factor: " & VBA.Format(x, "0.00") End Sub
Philippe.
