Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Accessing a parts list
3 REPLIES 3
timlogan3847
352 Views, 3 Replies
We have written a VB6 program for non-Inventor users that uses the Autodesk Inventor Object Library from an install of the Inventor Viewer 2011-2012.  The program collects drawing sets from a VaultMirror folder exported from the actual Inventor vault.  In addition, the program exports assembly parts to a formatted Excel file for purchasing.
We thought that it worked fine but, have recently found an issue: the program reads and exports ALL items referenced in an assembly, not just items in the parts list.  For a particular assembly that I am using to test with, there are seven items in the parts list but, 23 parts referenced in total in the assembly.  So, we get an Excel export with 23 + line items and when plotting to pdf, get 23 pdf files instead of the seven that should be created.
We are using the ApprenticeServerComponent to open the file objects but, I can't find a parts list.  I have reviewed a number of posted examples of accesing parts lists and opening ApprenticeServerDrawingDocument objects but, nothing seems to work.  It is like I don't have access to all of the object types needed to make it happen.
Should I be trying to open an iam or idw to access the parts list?
Are there any very basic code examples available of accessing a parts list?
3 REPLIES 3
skyngu
in reply to: timlogan3847
you need to place a partslist in a idw first. then you can access partslist from vb.
Autodesk Inventor Professional 2019
PoYHove
Hi Tim
did you manage to get it working ?
timlogan3847
in reply to: PoYHove
Yes, we got it working.
The inventor viewer is enough to plot drawings. To access the boms, you
need a full inventor install.
Tim Logan
RMT Robotics (A Cimcorp Oy Company)
Network Support
Phone: 905-643-9700 Ext 272
Fax: 905-643-9666
www.rmtrobotics.com
www.cimcorp.com
RMT Robotics, 635 South Service Rd, Grimsby,
Ontario, Canada, L3M 4E8
The information contained in this E-mail is confidential and intended
only for the use of the addressee(s). If you have received this
communication in error, please delete or destroy any copies of it.
