Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Access to Save As screen
3 REPLIES 3
eder
422 Views, 3 Replies
Hello
I have a problem for code files in inventor, my intention is codify this files whit a personal code name.
I need to launch the "SAVE AS" changing the file name that I need, with the possibility of modifying it.
ThisApplication.CommandManager.ControlDefinitions.Item ("AppFileNewCmd"). Execute
Works smoothly and launches the open document window, but
ThisApplication.CommandManager.ControlDefinitions.Item ("AppFileSaveAsCmd"). Execute
does nothing, either fails. At the same time would need to know how to rename the file to display.
Thanks, very much
3 REPLIES 3
philippe.leefsma
in reply to: eder
Which version of Inventor are you using? The following code works fine on my side under 2014:
Public Sub ExecuteCommand()
ThisApplication.CommandManager.ControlDefinitions.item("AppFileSaveAsCmd").Execute
End Sub
Take a look at "FileUIEvents.OnFileSaveAsDialog" it provides a way to customize the proposed filename when SaveAs dialog pops up, if I understand correcly your question.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
eder
in reply to: eder
Hello Philipe
I'm using  inventor 20013 in my computer.  I solve the "save as" question. Thanks
But i have another question. Please , do you know if i can't modify the image of icons in parts and assemblies??
I know to change the icon who appears up of tool bar in part and assembly screen , but i don't know change the general icon.
philippe.leefsma
in reply to: eder
I'm not sure which icon you are talking about, is it an icon you see in Inventor or you mean the icon of the file system?
I don't know of a way to change native icons in general, that's not something that developers want usually to customize.
Philippe.
Philippe Leefsma
